Einleitung
This guide will walk you through the steps of replacing a malfunctioning or non-functional fan in an Acer Nitro 5 AN515-44-R70B. If your laptop is generating excessive heat or noise, especially during resource-intensive activities like gaming, it could be a sign of a fan-related issue.
Was du brauchst
Use the Phillips #0 screwdriver to remove the eleven M2.5x6.0 size screws holding the back cover in place.
For extra caution slide out the battery cable from its connector using your fingers.
Use the Phillips #0 screwdriver to remove the four M2.5x6.0 size screws holding the fan assembly in place.
You can now remove the old fans and replace them with new ones.
