Zum Hauptinhalt wechseln
Acer Nitro 5 AN515-53-52FA Battery Replacement
Was du brauchst
  1. Acer Nitro 5 AN515-53-52FA Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Before starting the replacement, make sure the laptop is turned off and unplugged.
    • Flip the laptop upside down so that the bottom is facing up.
  2. Acer Nitro 5 AN515-53-52FA Battery Replacement: Schritt 2, Bild 1 von 2 Acer Nitro 5 AN515-53-52FA Battery Replacement: Schritt 2, Bild 2 von 2
    • Use the Phillips #0 screwdriver to unscrew the sixteen 9 mm screws holding the back cover in place.
  3. Acer Nitro 5 AN515-53-52FA Battery Replacement: Schritt 3, Bild 1 von 2 Acer Nitro 5 AN515-53-52FA Battery Replacement: Schritt 3, Bild 2 von 2
    • Use the opening pick to work your way around the edges to remove the bottom case carefully.
    • Do not try to put too much force on the shell off as you may damage it.
  4. Acer Nitro 5 AN515-53-52FA Battery Replacement: Schritt 4, Bild 1 von 1
    • Use the Phillips #0 screwdriver to unscrew the four 9 mm screws holding the battery in place.
  5. Acer Nitro 5 AN515-53-52FA Battery Replacement: Schritt 5, Bild 1 von 2 Acer Nitro 5 AN515-53-52FA Battery Replacement: Schritt 5, Bild 2 von 2
    • Disconnect the battery's motherboard connector with your fingers.
  6. Acer Nitro 5 AN515-53-52FA Battery Replacement: Schritt 6, Bild 1 von 2 Acer Nitro 5 AN515-53-52FA Battery Replacement: Schritt 6, Bild 2 von 2
    • Lift the battery up and out of the laptop.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Gateway, Team 1-3, Pee Fall 2022 Mitglied von Gateway, Team 1-3, Pee Fall 2022
GCC-PEE-F22S1G3
4 Mitglieder
5 Anleitungen geschrieben
2 Kommentare
Do I have to use other material to put the bottom case back on or is it easy to do by hand?
SomeDude372 - Antwort
Can I use a Jimmy instead of the opening picks?
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 7
Letzte 7 Tage: 25
Letzte 30 Tage: 80
Insgesamt: 950
