Zum Hauptinhalt wechseln
Einleitung
Use this guide to replace the Speakers in the Acer Nitro 5 Acer Nitro 5 AN515-53-55G9. This laptop has two speakers that come installed into the device.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Make sure  laptop is off and unplugged before beginning replacement. Flip  the laptop upside down so that the bottom is facing up. Identify the RAM tray on the bottom of the laptop.
    • Make sure laptop is off and unplugged before beginning replacement.
    • Flip the laptop upside down so that the bottom is facing up.
    • Identify the RAM tray on the bottom of the laptop.
  2. Use the Phillips #0 screwdriver to remove the 9mm screw in the bottom left corner of the RAM tray covering. Remove the RAM tray cover by prying up with a spudger. Remove the RAM tray cover by prying up with a spudger.
    • Use the Phillips #0 screwdriver to remove the 9mm screw in the bottom left corner of the RAM tray covering.
    • Remove the RAM tray cover by prying up with a spudger.
  3. Identify the Hard Drive tray to the left side of the laptop. Remove screw with a #0 Philips screwdriver. Lift up the Slot covering using a spunger.
    • Identify the Hard Drive tray to the left side of the laptop.
    • Remove screw with a #0 Philips screwdriver.
    • Lift up the Slot covering using a spunger.
  4. Use the Phillips #0 screwdriver to remove the 9mm screws holding the back cover in place.
    • Use the Phillips #0 screwdriver to remove the 9mm screws holding the back cover in place.
  5. Carefully remove the back shell from the device working your way around all the edges. Do not forcefully try to separate the shell as you may cause harm to the shell. Do not forcefully try to separate the shell as you may cause harm to the shell.
    • Carefully remove the back shell from the device working your way around all the edges.
    • Do not forcefully try to separate the shell as you may cause harm to the shell.
  6. Removing the back shell of the computer and it will look like this. The battery for the device is located at the bottom middle of the laptop at this orientation.
    • Removing the back shell of the computer and it will look like this.
    • The battery for the device is located at the bottom middle of the laptop at this orientation.
  7. Locate the connector of the battery to the motherboard. Using your fingers, slide out the connector. Using your fingers, slide out the connector.
    • Locate the connector of the battery to the motherboard.
    • Using your fingers, slide out the connector.
  8. Remove battery from device.
    • Remove battery from device.
  9. Once the battery is removed your device should look similar to this. Locate the plug for the speakers located at the red circle. Locate the plug for the speakers located at the red circle.
    • Once the battery is removed your device should look similar to this.
    • Locate the plug for the speakers located at the red circle.
  10. Unplug the cable from the motherboard as shown. Carefully unroute the cables starting from the main plug.
    • Unplug the cable from the motherboard as shown.
    • Carefully unroute the cables starting from the main plug.
    • Do not forcefully pull on the cable as it might break the cable.
  11. Pull up on the left speaker as shown here to remove the speaker from the device. the rubber grommets from the speaker my pop off. These can easily be placed back on.
    • Pull up on the left speaker as shown here to remove the speaker from the device.
    • the rubber grommets from the speaker my pop off. These can easily be placed back on.
  12. Continue unrouting the cable from the device and following it to the right speaker. Do not pull on the wire forcefully or it might break the cable.
    • Continue unrouting the cable from the device and following it to the right speaker.
    • Do not pull on the wire forcefully or it might break the cable.
  13. Locate the Right Speaker on the device. Pull up on the speaker to remove from the device.
    • Locate the Right Speaker on the device.
    • Pull up on the speaker to remove from the device.
    • Rubber grommets from the speaker my pop off. These can easily be placed back on.
Abschluss
3 weitere Nutzer haben diese Anleitung absolviert.
Do you have an Android application?
DERDOURI TOUFIK - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 3
Letzten 7 Tage: 41
Letzten 30 Tage: 143
Insgesamt: 2,701
