Zum Hauptinhalt wechseln
Acer Nitro 5 AN515-53-55G9 Wi-Fi Card Replacement
Was du brauchst
  1. Acer Nitro 5 AN515-53-55G9 Wi-Fi Card Replacement, Wi-Fi Card: Schritt 1, Bild 1 von 2 Acer Nitro 5 AN515-53-55G9 Wi-Fi Card Replacement, Wi-Fi Card: Schritt 1, Bild 2 von 2
    • Flip the laptop upside down so that the bottom is facing up.
  2. Acer Nitro 5 AN515-53-55G9 Wi-Fi Card Replacement: Schritt 2, Bild 1 von 3 Acer Nitro 5 AN515-53-55G9 Wi-Fi Card Replacement: Schritt 2, Bild 2 von 3 Acer Nitro 5 AN515-53-55G9 Wi-Fi Card Replacement: Schritt 2, Bild 3 von 3
    • Use the Phillips #0 screwdriver to remove the 9mm screw in the bottom left corner of the RAM tray covering.
    • Remove the RAM tray cover by prying it up with a plastic opening tool.
  3. Acer Nitro 5 AN515-53-55G9 Wi-Fi Card Replacement: Schritt 3, Bild 1 von 2 Acer Nitro 5 AN515-53-55G9 Wi-Fi Card Replacement: Schritt 3, Bild 2 von 2
    • Remove the screw on the Hard Drive tray with a Phillips #0 screwdriver.
    • Lift up the tray covering using a plastic opening tool.
  4. Acer Nitro 5 AN515-53-55G9 Wi-Fi Card Replacement: Schritt 4, Bild 1 von 1
    • Use the Phillips #0 screwdriver to remove the fourteen 9mm screws holding the back cover in place.
    • Remove the hard drive (if applicable) from the slot prior to removing the back cover.
    • This device didn't have a hard drive so your device may look different.
  5. Acer Nitro 5 AN515-53-55G9 Wi-Fi Card Replacement: Schritt 5, Bild 1 von 3 Acer Nitro 5 AN515-53-55G9 Wi-Fi Card Replacement: Schritt 5, Bild 2 von 3 Acer Nitro 5 AN515-53-55G9 Wi-Fi Card Replacement: Schritt 5, Bild 3 von 3
    • Carefully remove the back shell from the device by prying at the creases with a spudger around all the edges.
    • Do not forcefully try to separate the shell as you may cause harm to the shell.
  6. Acer Nitro 5 AN515-53-55G9 Wi-Fi Card Replacement: Schritt 6, Bild 1 von 1
    • Lift the back cover off once all the clips have been disengaged.
  7. Acer Nitro 5 AN515-53-55G9 Wi-Fi Card Replacement: Schritt 7, Bild 1 von 3 Acer Nitro 5 AN515-53-55G9 Wi-Fi Card Replacement: Schritt 7, Bild 2 von 3 Acer Nitro 5 AN515-53-55G9 Wi-Fi Card Replacement: Schritt 7, Bild 3 von 3
    • Using your fingers, disconnect the white and black cables connected to the left side of the Wi-fi card.
  8. Acer Nitro 5 AN515-53-55G9 Wi-Fi Card Replacement: Schritt 8, Bild 1 von 3 Acer Nitro 5 AN515-53-55G9 Wi-Fi Card Replacement: Schritt 8, Bild 2 von 3 Acer Nitro 5 AN515-53-55G9 Wi-Fi Card Replacement: Schritt 8, Bild 3 von 3
    • Remove the screw holding down the Wi-Fi card with a Phillips #0 screwdriver.
  9. Acer Nitro 5 AN515-53-55G9 Wi-Fi Card Replacement: Schritt 9, Bild 1 von 2 Acer Nitro 5 AN515-53-55G9 Wi-Fi Card Replacement: Schritt 9, Bild 2 von 2
    • Slide the Wi-Fi card out from its port.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
1 Kommentar zur Anleitung
My hard drive got disconnected and I can't locate where is the place to connect it
manueltopete59 - Antwort Teilen
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 14
Letzte 30 Tage: 55
Insgesamt: 7,724
