Einleitung
The fans inside the Acer Nitro 5 AN515-55-53AG laptop can occasionally get stuck, dusty, or fail completely. Fans are essential to the operation of a graphics card (GPU) or central processor (CPU). They help keep the graphics card operating at a low temperature. The GPU will quickly overheat and shut down if the fans are removed or malfunction. Fixing this is often a matter of some small handiwork to get inside the computer and check the fans for what might be sticking. Use this guide to access the internal GPU/CPU cooling fan. From here, it is possible to unjam, clean, or replace the fan as needed.
Was du brauchst
Use your Phillips #0 screwdriver to remove the eleven screws holding down the laptop's bottom cover.
Remove the laptop's bottom cover using an opening tool or plastic card.
Remove the two screws holding the fan in place using a Phillips #0 screwdriver.
Remove the old fan by pulling it directly up.
While the fan is out, clean the space with a cloth or a can of compressed air. Clean the fan vents and plate of any dust.
2 weitere Personen haben diese Anleitung absolviert.
Ein Kommentar
на an515-55-534c система охлаждения так же разбирается ? или это он и есть ?
