Zum Hauptinhalt wechseln
Acer Nitro 5 AN515-55-55M1 Battery Replacement
Was du brauchst
  1. Acer Nitro 5 AN515-55-55M1 Battery Replacement, Bottom Cover: Schritt 1, Bild 1 von 1
    • Make sure the device is off and unplugged from power.
    • Flip the device so the bottom is facing up.
    • Remove 11 screws from the bottom case using a Phillips #1 screwdriver.
  2. Acer Nitro 5 AN515-55-55M1 Battery Replacement: Schritt 2, Bild 1 von 2 Acer Nitro 5 AN515-55-55M1 Battery Replacement: Schritt 2, Bild 2 von 2
    • Lift the top left and right corners up and away from the device.
    • This may require some force and will make harsh clicking sounds. This is normal; it's the plastic tabs separating from each other.
    • Remove the panel from the laptop.
  3. Acer Nitro 5 AN515-55-55M1 Battery Replacement, Battery: Schritt 3, Bild 1 von 3 Acer Nitro 5 AN515-55-55M1 Battery Replacement, Battery: Schritt 3, Bild 2 von 3 Acer Nitro 5 AN515-55-55M1 Battery Replacement, Battery: Schritt 3, Bild 3 von 3
    • Use an opening tool to disconnect the battery from the motherboard.
  4. Acer Nitro 5 AN515-55-55M1 Battery Replacement: Schritt 4, Bild 1 von 2 Acer Nitro 5 AN515-55-55M1 Battery Replacement: Schritt 4, Bild 2 von 2
    • Remove the two screws from the battery with a Phillips #1 screwdriver.
    • Remove the battery by pulling up and out from the left side.
Abschluss
Congratulations! You have successfully replaced the battery of your Acer Nitro 5 AN515-55-55M1!
2 weitere Nutzer:innen haben diese Anleitung absolviert.
UMass Dartmouth, Team 1-4, Mellen Spring 2022 Mitglied von UMass Dartmouth, Team 1-4, Mellen Spring 2022
UMASSD-MELLEN-S22S1G4
3 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 14
Letzte 7 Tage: 56
Letzte 30 Tage: 276
Insgesamt: 8,164
