Was du brauchst
Make sure the device is off and unplugged from power.
Flip the device so the bottom is facing up.
Remove 11 screws from the bottom case using a Phillips #1 screwdriver.
Lift the top left and right corners up and away from the device.
Remove the panel from the laptop.
Remove the two screws from the battery with a Phillips #1 screwdriver.
Remove the battery by pulling up and out from the left side.
Disconnect the seven cables from the motherboard using an iFixit opening tool.
Use an iFixit opening tool to lift the two Wi-Fi antenna cables up and away from the Wi-Fi card.
Remove the six screws surrounding the fan using a Phillips #1 screwdriver.
Remove the two shorter screws from the motherboard using a Phillips #1 screwdriver.
Lift the taped wires off of the fans on the right and left sides.
Lift up the right side of the motherboard.
Continue to lift at an angle until there is a give.
Remove the motherboard and fans from the laptop.
Unplug the two fan connectors from each side of the motherboard using an opening tool.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
