Zum Hauptinhalt wechseln
Acer Nitro 5 AN515-55-55M1 Motherboard Replacement
Was du brauchst
  1. Acer Nitro 5 AN515-55-55M1 Motherboard Replacement, Bottom Cover: Schritt 1, Bild 1 von 1
    • Make sure the device is off and unplugged from power.
    • Flip the device so the bottom is facing up.
    • Remove 11 screws from the bottom case using a Phillips #1 screwdriver.
  2. Acer Nitro 5 AN515-55-55M1 Motherboard Replacement: Schritt 2, Bild 1 von 2 Acer Nitro 5 AN515-55-55M1 Motherboard Replacement: Schritt 2, Bild 2 von 2
    • Lift the top left and right corners up and away from the device.
    • This may require some force and will make harsh clicking sounds. This is normal; it's the plastic tabs separating from each other.
    • Remove the panel from the laptop.
  3. Acer Nitro 5 AN515-55-55M1 Motherboard Replacement, Battery: Schritt 3, Bild 1 von 3 Acer Nitro 5 AN515-55-55M1 Motherboard Replacement, Battery: Schritt 3, Bild 2 von 3 Acer Nitro 5 AN515-55-55M1 Motherboard Replacement, Battery: Schritt 3, Bild 3 von 3
    • Use an opening tool to disconnect the battery from the motherboard.
  4. Acer Nitro 5 AN515-55-55M1 Motherboard Replacement: Schritt 4, Bild 1 von 2 Acer Nitro 5 AN515-55-55M1 Motherboard Replacement: Schritt 4, Bild 2 von 2
    • Remove the two screws from the battery with a Phillips #1 screwdriver.
    • Remove the battery by pulling up and out from the left side.
  5. Acer Nitro 5 AN515-55-55M1 Motherboard Replacement, Motherboard: Schritt 5, Bild 1 von 3 Acer Nitro 5 AN515-55-55M1 Motherboard Replacement, Motherboard: Schritt 5, Bild 2 von 3 Acer Nitro 5 AN515-55-55M1 Motherboard Replacement, Motherboard: Schritt 5, Bild 3 von 3
    • Disconnect the seven cables from the motherboard using an iFixit opening tool.
  6. Acer Nitro 5 AN515-55-55M1 Motherboard Replacement: Schritt 6, Bild 1 von 3 Acer Nitro 5 AN515-55-55M1 Motherboard Replacement: Schritt 6, Bild 2 von 3 Acer Nitro 5 AN515-55-55M1 Motherboard Replacement: Schritt 6, Bild 3 von 3
    • Use an iFixit opening tool to lift the two Wi-Fi antenna cables up and away from the Wi-Fi card.
  7. Acer Nitro 5 AN515-55-55M1 Motherboard Replacement: Schritt 7, Bild 1 von 3 Acer Nitro 5 AN515-55-55M1 Motherboard Replacement: Schritt 7, Bild 2 von 3 Acer Nitro 5 AN515-55-55M1 Motherboard Replacement: Schritt 7, Bild 3 von 3
    • Remove the six screws surrounding the fan using a Phillips #1 screwdriver.
    • Remove the two shorter screws from the motherboard using a Phillips #1 screwdriver.
    • Lift the taped wires off of the fans on the right and left sides.
  8. Acer Nitro 5 AN515-55-55M1 Motherboard Replacement: Schritt 8, Bild 1 von 3 Acer Nitro 5 AN515-55-55M1 Motherboard Replacement: Schritt 8, Bild 2 von 3 Acer Nitro 5 AN515-55-55M1 Motherboard Replacement: Schritt 8, Bild 3 von 3
    • Lift up the right side of the motherboard.
    • The cables may need some guidance to leave the management holes on the motherboard.
    • Continue to lift at an angle until there is a give.
    • Remove the motherboard and fans from the laptop.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
UMass Dartmouth, Team 1-4, Mellen Spring 2022 Mitglied von UMass Dartmouth, Team 1-4, Mellen Spring 2022
UMASSD-MELLEN-S22S1G4
3 Mitglieder
5 Anleitungen geschrieben
Ein Kommentar
Where would I go to buy a new motherboard and display?
David Nguyen - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 8
Letzte 7 Tage: 38
Letzte 30 Tage: 135
Insgesamt: 5,392
