Was du brauchst
Make sure the device is off and unplugged from power.
Flip the device so the bottom is facing up.
Remove 11 screws from the bottom case using a Phillips #1 screwdriver.
Lift the top left and right corners up and away from the device.
Remove the panel from the laptop.
Use an iFixit opening tool to unplug both speaker connectors from the motherboard.
Fast fertig!
Abschluss
