Zum Hauptinhalt wechseln
Acer Nitro 5 AN515-55-56GN HDD Replacement
Was du brauchst
  1. Acer Nitro 5 AN515-55-56GN HDD Replacement, HDD: Schritt 1, Bild 1 von 3 Acer Nitro 5 AN515-55-56GN HDD Replacement, HDD: Schritt 1, Bild 2 von 3 Acer Nitro 5 AN515-55-56GN HDD Replacement, HDD: Schritt 1, Bild 3 von 3
    • Turn off the laptop and unplug it from the charging cord.
    • Flip the laptop over so the backside is facing up.
    • Use a Phillips #0 screwdriver to remove ten 9 mm screws.
  2. Acer Nitro 5 AN515-55-56GN HDD Replacement: Schritt 2, Bild 1 von 3 Acer Nitro 5 AN515-55-56GN HDD Replacement: Schritt 2, Bild 2 von 3 Acer Nitro 5 AN515-55-56GN HDD Replacement: Schritt 2, Bild 3 von 3
    • Use your fingers or an opening tool to remove the back case by separating it at the seam.
    • Work your way gently around the perimeter to undo the clips.
    • Remove the back case.
  3. Acer Nitro 5 AN515-55-56GN HDD Replacement: Schritt 3, Bild 1 von 3 Acer Nitro 5 AN515-55-56GN HDD Replacement: Schritt 3, Bild 2 von 3 Acer Nitro 5 AN515-55-56GN HDD Replacement: Schritt 3, Bild 3 von 3
    • Unplug the battery cable from the connector attaching the battery to the motherboard.
    • Make sure that the laptop battery is unplugged or remove the battery before installing the HDD.
  4. Acer Nitro 5 AN515-55-56GN HDD Replacement: Schritt 4, Bild 1 von 3 Acer Nitro 5 AN515-55-56GN HDD Replacement: Schritt 4, Bild 2 von 3 Acer Nitro 5 AN515-55-56GN HDD Replacement: Schritt 4, Bild 3 von 3
    • Use the Phillips #0 screwdriver to remove four 3 mm screws from the hard drive bracket.
    • Remove the bracket from the device.
  5. Acer Nitro 5 AN515-55-56GN HDD Replacement: Schritt 5, Bild 1 von 3 Acer Nitro 5 AN515-55-56GN HDD Replacement: Schritt 5, Bild 2 von 3 Acer Nitro 5 AN515-55-56GN HDD Replacement: Schritt 5, Bild 3 von 3
    • Place the HDD 1TB in the bracket.
    • Use the Phillips #0 screwdriver to secure the 2 mm screws that hold the HDD in the bracket.
    • The 2 mm screws are included with the new HDD.
  6. Acer Nitro 5 AN515-55-56GN HDD Replacement: Schritt 6, Bild 1 von 2 Acer Nitro 5 AN515-55-56GN HDD Replacement: Schritt 6, Bild 2 von 2
    • Attach the SATA connector to the HDD.
  7. Acer Nitro 5 AN515-55-56GN HDD Replacement: Schritt 7, Bild 1 von 2 Acer Nitro 5 AN515-55-56GN HDD Replacement: Schritt 7, Bild 2 von 2
    • Slide the HDD into the socket on the motherboard.
    • Replace the four 3 mm screws using the Phillips #0 screwdriver.
  8. Acer Nitro 5 AN515-55-56GN HDD Replacement: Schritt 8, Bild 1 von 3 Acer Nitro 5 AN515-55-56GN HDD Replacement: Schritt 8, Bild 2 von 3 Acer Nitro 5 AN515-55-56GN HDD Replacement: Schritt 8, Bild 3 von 3
    • Slide the hard drive cable into the connector on the motherboard.
    • Flip the black lock down to secure the cable.
Abschluss
That is all step-to-step on how to Install the new HDD to the laptop Acer Nitro 5 (AN515-55-56GN)
5 weitere Nutzer:innen haben diese Anleitung absolviert.
Duy Nguyen
253 Reputation
1 Anleitung geschrieben
York University, Team M-17, Allen Summer 2022 Mitglied von York University, Team M-17, Allen Summer 2022
YORK-ALLEN-SU22SMG17
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 10
Letzte 7 Tage: 45
Letzte 30 Tage: 200
Insgesamt: 4,874
