Zum Hauptinhalt wechseln
Acer Nitro 5 AN515-57 RAM Replacement
Was du brauchst
  1. Acer Nitro 5 AN515-57 RAM Replacement, RAM: Schritt 1, Bild 1 von 2 Acer Nitro 5 AN515-57 RAM Replacement, RAM: Schritt 1, Bild 2 von 2
    • Shut-down your laptop and unplug the battery connection.
    • Remove any other device attached to the laptop.
  2. Acer Nitro 5 AN515-57 RAM Replacement: Schritt 2, Bild 1 von 1
    • Remove eleven screws from the bottom case of the laptop using a Phillips #00 screwdriver.
  3. Acer Nitro 5 AN515-57 RAM Replacement: Schritt 3, Bild 1 von 2 Acer Nitro 5 AN515-57 RAM Replacement: Schritt 3, Bild 2 von 2
    • Slide an iFixit opening tool into the front lip of the laptop and slowly move your way around the chassis.
    • Make sure not to slide the tool too deep as it can damage the board.
  4. Acer Nitro 5 AN515-57 RAM Replacement: Schritt 4, Bild 1 von 2 Acer Nitro 5 AN515-57 RAM Replacement: Schritt 4, Bild 2 von 2
    • Disconnect the battery by either using the iFixit opening tool or your fingers.
  5. Acer Nitro 5 AN515-57 RAM Replacement: Schritt 5, Bild 1 von 3 Acer Nitro 5 AN515-57 RAM Replacement: Schritt 5, Bild 2 von 3 Acer Nitro 5 AN515-57 RAM Replacement: Schritt 5, Bild 3 von 3
    • Use your fingers to pull the silver latches on either side of the RAM away from each other.
    • The RAM will pop up by a few centimeters.
    • Remove the RAM from the laptop.
  6. Acer Nitro 5 AN515-57 RAM Replacement: Schritt 6, Bild 1 von 1
    • Reconnect the battery pins
    • While reconnecting the battery, try not to touch the metal prongs.
  7. Acer Nitro 5 AN515-57 RAM Replacement: Schritt 7, Bild 1 von 2 Acer Nitro 5 AN515-57 RAM Replacement: Schritt 7, Bild 2 von 2
    • Place the back panel on to your laptop and gently press on it until it snaps in place.
    • Screw the back panel back in.
    • When turning on your laptop the first time after installing new RAM, it may take the laptop a few minutes to turn on.
Ziellinie
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Hanzala Mir
170 Reputation
1 Anleitung geschrieben
York University, Team S-18, Woodhouse Winter 2022 Mitglied von York University, Team S-18, Woodhouse Winter 2022
YORK-WOODHOUSE-W22SSG18
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 9
Letzte 7 Tage: 37
Letzte 30 Tage: 174
Insgesamt: 4,321
