Zum Hauptinhalt wechseln
Acer Nitro 5 AN517-51-56YW Touch Pad Replacement
Was du brauchst
  1. Acer Nitro 5 AN517-51-56YW Touch Pad Replacement, Bottom Cover: Schritt 1, Bild 1 von 3 Acer Nitro 5 AN517-51-56YW Touch Pad Replacement, Bottom Cover: Schritt 1, Bild 2 von 3 Acer Nitro 5 AN517-51-56YW Touch Pad Replacement, Bottom Cover: Schritt 1, Bild 3 von 3
    • Place the laptop upside-down so that the fans are facing away from you.
    • Remove the twelve 6.7 mm screws from the bottom cover using a Phillips #1 screwdriver.
    • Pry the bottom cover away from the laptop using a spudger.
  2. Acer Nitro 5 AN517-51-56YW Touch Pad Replacement, Battery: Schritt 2, Bild 1 von 2 Acer Nitro 5 AN517-51-56YW Touch Pad Replacement, Battery: Schritt 2, Bild 2 von 2
    • Unplug the connection plug that attaches the battery to the motherboard.
    • Make sure to pull the connector safely so that it doesn't break.
    • Remove the two 4.7 mm screws using a Phillips #1 screwdriver.
  3. Acer Nitro 5 AN517-51-56YW Touch Pad Replacement: Schritt 3, Bild 1 von 2 Acer Nitro 5 AN517-51-56YW Touch Pad Replacement: Schritt 3, Bild 2 von 2
    • Remove the battery from the laptop.
    • Make sure that your laptop powers on before you begin reassembly. If it does not start, make sure the battery is firmly connected to the motherboard.
  4. Acer Nitro 5 AN517-51-56YW Touch Pad Replacement, Touch Pad: Schritt 4, Bild 1 von 2 Acer Nitro 5 AN517-51-56YW Touch Pad Replacement, Touch Pad: Schritt 4, Bild 2 von 2
    • Remove the two 3.7 mm screws from the silver bracing plate using a Phillips #1 screwdriver.
    • Detach the touch pad connector by lifting the clamp and pulling on the blue tab.
    • Lift the adhesive ribbon to be able to remove the touchpad.
    • Do not remove the ribbon completely, only the part that is on the touchpad.
  5. Acer Nitro 5 AN517-51-56YW Touch Pad Replacement: Schritt 5, Bild 1 von 2 Acer Nitro 5 AN517-51-56YW Touch Pad Replacement: Schritt 5, Bild 2 von 2
    • Lift the touchpad towards you from the bottom.
Abschluss
University of Memphis, Team 3-1, Lane Fall 2022 Mitglied von University of Memphis, Team 3-1, Lane Fall 2022
UM-LANE-F22S3G1
5 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 19
Insgesamt: 269
