Zum Hauptinhalt wechseln
Acer One 10 S1002 145-A Battery Replacement
Was du brauchst
  1. Acer One 10 S1002 145-A Battery Replacement, Motherboard: Schritt 1, Bild 1 von 1
    • Make sure that the tablet is turned off and disconnected from any power source.
    • Disconnect the tablet from the keyboard attachment.
    • If you have a Micro SD card in the tablet, remove it now.
    • Remove the two 3.5 mm Phillips #0 screws on either side the keyboard connection.
  2. Acer One 10 S1002 145-A Battery Replacement: Schritt 2, Bild 1 von 2 Acer One 10 S1002 145-A Battery Replacement: Schritt 2, Bild 2 von 2
    • Starting from a corner of the tablet, use the plastic opening tool to create a gap between the screen and the back covering.
    • Slowly maneuver the plastic opening tool along the perimeter of the tablet to pry the screen and back covering apart.
    • Separate the back covering from the screen.
  3. Acer One 10 S1002 145-A Battery Replacement: Schritt 3, Bild 1 von 3 Acer One 10 S1002 145-A Battery Replacement: Schritt 3, Bild 2 von 3 Acer One 10 S1002 145-A Battery Replacement: Schritt 3, Bild 3 von 3
    • Peel off all of the Polyimide tape (yellow tape).
    • Remove the metallic tape covering the keyboard connection.
  4. Acer One 10 S1002 145-A Battery Replacement: Schritt 4, Bild 1 von 2 Acer One 10 S1002 145-A Battery Replacement: Schritt 4, Bild 2 von 2
    • Unscrew the two 3.5mm Phillips #0 screws and open the ZIF latch.
    • Gently remove the silver part covering the battery and set it aside.
  5. Acer One 10 S1002 145-A Battery Replacement: Schritt 5, Bild 1 von 3 Acer One 10 S1002 145-A Battery Replacement: Schritt 5, Bild 2 von 3 Acer One 10 S1002 145-A Battery Replacement: Schritt 5, Bild 3 von 3
  6. Acer One 10 S1002 145-A Battery Replacement: Schritt 6, Bild 1 von 2 Acer One 10 S1002 145-A Battery Replacement: Schritt 6, Bild 2 von 2
    • Remove the four 4mm screws at the corners of the motherboard with the Phillips#0 bit screw.
    • The screw beneath the metallic tape also needs to be removed.
  7. Acer One 10 S1002 145-A Battery Replacement: Schritt 7, Bild 1 von 3 Acer One 10 S1002 145-A Battery Replacement: Schritt 7, Bild 2 von 3 Acer One 10 S1002 145-A Battery Replacement: Schritt 7, Bild 3 von 3
    • Disconnect the three cables on the motherboard closest to the battery.
    • These cables require some extra prying power to be removed.
  8. Acer One 10 S1002 145-A Battery Replacement: Schritt 8, Bild 1 von 1
    • Slide out the motherboard and put it aside.
  9. Acer One 10 S1002 145-A Battery Replacement, Battery: Schritt 9, Bild 1 von 3 Acer One 10 S1002 145-A Battery Replacement, Battery: Schritt 9, Bild 2 von 3 Acer One 10 S1002 145-A Battery Replacement, Battery: Schritt 9, Bild 3 von 3
    • Use the plastic opening tool to separate the glue that holds the battery to the screen.
    • Avoid putting pressure on the glass while separating the battery from the screen.
    • Remove the battery and set it aside.
Abschluss
20 weitere Nutzer:innen haben diese Anleitung absolviert.
Shannon Griffin
1.372 Reputation
5 Anleitungen geschrieben
USF Tampa, Team 1-3, Sullivan Fall 2016 Mitglied von USF Tampa, Team 1-3, Sullivan Fall 2016
USFT-SULLIVAN-F16S1G3
4 Mitglieder
2 Kommentare
Thankyou for this information. I am replacing a battery on my own, and your tutorial is extremely clear and helpful.
shop_arod - Antwort
I want a ..
Motherboard
4D Guru Channel - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 13
Letzte 30 Tage: 38
Insgesamt: 18,640
