Zum Hauptinhalt wechseln
Acer One 10 S1003-114M Key Replacement
Was du brauchst
  1. Acer One 10 S1003-114M Key Replacement, Key: Schritt 1, Bild 1 von 2 Acer One 10 S1003-114M Key Replacement, Key: Schritt 1, Bild 2 von 2
    • Make sure your device is powered off and disconnected from any power supply.
    • Open the laptop and disconnect the tablet screen from the magnetic keyboard dock by gently lifting the screen up.
    • Use tweezers to gently pry up the damaged key.
  2. Acer One 10 S1003-114M Key Replacement: Schritt 2, Bild 1 von 1
    • White plastic springs may become misaligned when removing key.
    • If the plastic springs do become misaligned, use tweezers to realign springs by popping them back into their horizontal placement.
Abschluss
Ein Kommentar
Is there any place we can buy replacement keys?
Nur Ahmad Furlong - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 25
Insgesamt: 3,077
