Zum Hauptinhalt wechseln
Acer One 10 S1003-19GY Back Panel Replacement
Was du brauchst
  1. Acer One 10 S1003-19GY Back Panel Replacement, Back Panel: Schritt 1, Bild 1 von 2 Acer One 10 S1003-19GY Back Panel Replacement, Back Panel: Schritt 1, Bild 2 von 2
    • Power off the device and make sure it is disconnected from any external devices.
    • Use a plastic opening tool to create a gap between the front and back casing of the device.
    • Slowly maneuver the plastic tool around the entire perimeter of the tablet to separate the front and back.
  2. Acer One 10 S1003-19GY Back Panel Replacement: Schritt 2, Bild 1 von 1
    • Set the device screen side down and remove the back casing.
Ziellinie
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 11
Insgesamt: 884
