Zum Hauptinhalt wechseln
Acer One 10 S1003-19GY Keyboard Ribbon/Dock Repair
Was du brauchst
  1. Acer One 10 S1003-19GY Keyboard Ribbon/Dock Repair, Back Panel: Schritt 1, Bild 1 von 2 Acer One 10 S1003-19GY Keyboard Ribbon/Dock Repair, Back Panel: Schritt 1, Bild 2 von 2
    • Power off the device and make sure it is disconnected from any external devices.
    • Use a plastic opening tool to create a gap between the front and back casing of the device.
    • Slowly maneuver the plastic tool around the entire perimeter of the tablet to separate the front and back.
  2. Acer One 10 S1003-19GY Keyboard Ribbon/Dock Repair: Schritt 2, Bild 1 von 1
    • Set the device screen side down and remove the back casing.
  3. Acer One 10 S1003-19GY Keyboard Ribbon/Dock Repair, Keyboard Ribbon/Dock: Schritt 3, Bild 1 von 3 Acer One 10 S1003-19GY Keyboard Ribbon/Dock Repair, Keyboard Ribbon/Dock: Schritt 3, Bild 2 von 3 Acer One 10 S1003-19GY Keyboard Ribbon/Dock Repair, Keyboard Ribbon/Dock: Schritt 3, Bild 3 von 3
    • Flip the latch and carefully pull the ribbon free.
  4. Acer One 10 S1003-19GY Keyboard Ribbon/Dock Repair: Schritt 4, Bild 1 von 2 Acer One 10 S1003-19GY Keyboard Ribbon/Dock Repair: Schritt 4, Bild 2 von 2
    • Remove the two screws holding the dock in place using a Phillips #0 screwdriver.
    • Pull the dock out and slide it out of the device.
Abschluss
Ein Kommentar
dove acquistare questo connettore :Acer ONE 10 (S1003 D16H1) Docking Port Connector Cable, grazie . francescomar25@gmail.com
Francesco - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 14
Insgesamt: 1,257
