Einleitung
The keyboard dock and ribbon will be removed in this guide.
Was du brauchst
Power off the device and make sure it is disconnected from any external devices.
Use a plastic opening tool to create a gap between the front and back casing of the device.
Slowly maneuver the plastic tool around the entire perimeter of the tablet to separate the front and back.
Remove the two screws holding the dock in place using a Phillips #0 screwdriver.
Pull the dock out and slide it out of the device.
