Zum Hauptinhalt wechseln
Acer One 10 S1003-19GY Rear/Front Camera Replacement
Was du brauchst
  1. Acer One 10 S1003-19GY Rear/Front Camera Replacement, Back Panel: Schritt 1, Bild 1 von 2 Acer One 10 S1003-19GY Rear/Front Camera Replacement, Back Panel: Schritt 1, Bild 2 von 2
    • Power off the device and make sure it is disconnected from any external devices.
    • Use a plastic opening tool to create a gap between the front and back casing of the device.
    • Slowly maneuver the plastic tool around the entire perimeter of the tablet to separate the front and back.
  2. Acer One 10 S1003-19GY Rear/Front Camera Replacement: Schritt 2, Bild 1 von 1
    • Set the device screen side down and remove the back casing.
  3. Acer One 10 S1003-19GY Rear/Front Camera Replacement, Front/Rear Camera: Schritt 3, Bild 1 von 1
    • Locate the Rear Camera in the upper right hand corner of the motherboard.
  4. Acer One 10 S1003-19GY Rear/Front Camera Replacement: Schritt 4, Bild 1 von 3 Acer One 10 S1003-19GY Rear/Front Camera Replacement: Schritt 4, Bild 2 von 3 Acer One 10 S1003-19GY Rear/Front Camera Replacement: Schritt 4, Bild 3 von 3
    • Using a relatively thin flat head screwdriver, pry the camera connection from the motherboard.
    • The connection should remove easily as it just snaps to the motherboard.
  5. Acer One 10 S1003-19GY Rear/Front Camera Replacement: Schritt 5, Bild 1 von 1
    • Remove the five screws on the outer edge of the motherboard using a Phillips #0 screwdriver.
  6. Acer One 10 S1003-19GY Rear/Front Camera Replacement: Schritt 6, Bild 1 von 2 Acer One 10 S1003-19GY Rear/Front Camera Replacement: Schritt 6, Bild 2 von 2
    • Open the black flap on the connection and gently pull the ribbon from it.
    • Slightly raise the motherboard from the upper side to remove the camera as shown.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 7
Insgesamt: 355
