Zum Hauptinhalt wechseln
Acer Predator 17 G9-791 Fan Assembly Replacement
Was du brauchst
  1. Acer Predator 17 G9-791 Fan Assembly Replacement, Service Panel: Schritt 1, Bild 1 von 1
    • The service panel can be located on the bottom of the device. It is shown here as the panel located in the middle of the device, going from the upper vents to the bottom of the device.
  2. Acer Predator 17 G9-791 Fan Assembly Replacement: Schritt 2, Bild 1 von 2 Acer Predator 17 G9-791 Fan Assembly Replacement: Schritt 2, Bild 2 von 2
    • Loosen the two Phillips #0 screws.
    • Pull up slightly on the top of the panel to help fully separate the screws from the rest of the device.
  3. Acer Predator 17 G9-791 Fan Assembly Replacement: Schritt 3, Bild 1 von 1
    • Continue pulling up on the panel to separate it from the laptop and remove it.
  4. Acer Predator 17 G9-791 Fan Assembly Replacement, Bottom Case: Schritt 4, Bild 1 von 3 Acer Predator 17 G9-791 Fan Assembly Replacement, Bottom Case: Schritt 4, Bild 2 von 3 Acer Predator 17 G9-791 Fan Assembly Replacement, Bottom Case: Schritt 4, Bild 3 von 3
    • Remove the nine 4.5 mm Phillips #0 screws from the panel.
    • Remove four 14 mm Phillips #0 screws.
    • Remove six 7 mm Phillips #0 screws.
  5. Acer Predator 17 G9-791 Fan Assembly Replacement: Schritt 5, Bild 1 von 1
    • Slide the "unlock" slider up located to the right of the service panel and pull the disc tray out.
  6. Acer Predator 17 G9-791 Fan Assembly Replacement: Schritt 6, Bild 1 von 1
    • Remove the two 4.5 mm Phillips #0 screws located underneath the removed optical drive.
  7. Acer Predator 17 G9-791 Fan Assembly Replacement: Schritt 7, Bild 1 von 2 Acer Predator 17 G9-791 Fan Assembly Replacement: Schritt 7, Bild 2 von 2
    • Pry up on the edges of the bottom cover and lift the bottom case off of the device.
  8. Acer Predator 17 G9-791 Fan Assembly Replacement, Battery: Schritt 8, Bild 1 von 1
    • Remove the six 4 mm Phillips #0 screws from the battery.
  9. Acer Predator 17 G9-791 Fan Assembly Replacement: Schritt 9, Bild 1 von 2 Acer Predator 17 G9-791 Fan Assembly Replacement: Schritt 9, Bild 2 von 2
    • Disconnect the battery connector from the motherboard.
  10. Acer Predator 17 G9-791 Fan Assembly Replacement: Schritt 10, Bild 1 von 1
    • Gently lift the battery and remove it from the device.
  11. Acer Predator 17 G9-791 Fan Assembly Replacement, Fan Assembly: Schritt 11, Bild 1 von 2 Acer Predator 17 G9-791 Fan Assembly Replacement, Fan Assembly: Schritt 11, Bild 2 von 2
    • Remove the five 4.5 mm Phillips #0 screws located on the perimeter of the fans.
  12. Acer Predator 17 G9-791 Fan Assembly Replacement: Schritt 12, Bild 1 von 2 Acer Predator 17 G9-791 Fan Assembly Replacement: Schritt 12, Bild 2 von 2
    • Unscrew the six Phillips #0 screws enough to loosen the assembly from the motherboard.
  13. Acer Predator 17 G9-791 Fan Assembly Replacement: Schritt 13, Bild 1 von 3 Acer Predator 17 G9-791 Fan Assembly Replacement: Schritt 13, Bild 2 von 3 Acer Predator 17 G9-791 Fan Assembly Replacement: Schritt 13, Bild 3 von 3
    • Detach the left fan's cord from the motherboard.
  14. Acer Predator 17 G9-791 Fan Assembly Replacement: Schritt 14, Bild 1 von 3 Acer Predator 17 G9-791 Fan Assembly Replacement: Schritt 14, Bild 2 von 3 Acer Predator 17 G9-791 Fan Assembly Replacement: Schritt 14, Bild 3 von 3
    • Detach the right fan's cord from the motherboard.
  15. Acer Predator 17 G9-791 Fan Assembly Replacement: Schritt 15, Bild 1 von 3 Acer Predator 17 G9-791 Fan Assembly Replacement: Schritt 15, Bild 2 von 3 Acer Predator 17 G9-791 Fan Assembly Replacement: Schritt 15, Bild 3 von 3
    • Lift the fan assembly up and out.
Abschluss
Grant Maffei
121 Reputation
1 Anleitung geschrieben
UMass Dartmouth, Team 5-1, Sinclaire Fall 2022 Mitglied von UMass Dartmouth, Team 5-1, Sinclaire Fall 2022
UMASSD-SINCLAIRE-F22S5G1
5 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 22
Insgesamt: 427
