Einleitung
The bundled cable connector is the electronic link between the motherboard and the monitor screen.
Was du brauchst
Place the monitor screen face down.
Firmly hold the base of the stand with one hand and the bottom of the monitor with the other hand.
Pull the stand away from the monitor.
Use the plastic opening tool to pry the back panel from the front panel.
Start at one point of the crease and pry along the entire monitor for the best results.
In diesem Schritt verwendetes Werkzeug:Magnetic Project Mat$19.95
Unscrew the four 7.5 mm Phillips #2 screws connecting the motherboard to the metal casing.
Pull the bundled cable connector gently away from motherboard.
Grasp the other side of the bundled cable connector and gently pull the connector away from the screen.
3 weitere Personen haben diese Anleitung absolviert.
