Einleitung
This guide will show you how to replace your Acer Spin 3 SP315-51-757C fan and heat sink. Leaving your laptop on for long periods of time or leaving it in a hot room could lead to issues with your heatsink and fan. If your laptop has been overheating or having temperature problems then they may need to be replaced.
Was du brauchst
Using an opening tool, pry open the back panel, starting at the silver screen hinges.
Remove the two Phillips #0 screws holding the battery inside the laptop case.
Using your hands, lift up on the battery from its slot, and carefully slide it away from you before fully lifting it out of the case.
Using a Phillips #0 screwdriver, remove the three screws that hold the fan on top of the motherboard.
Using a Phillips #0 screwdriver, remove the four screws that connect the heat sink to the motherboard.
