Einleitung
This is a guide instructing how to replace the Acer Spin 3 SP315-51-757C keyboard. Special Tool(s) to access the keyboard include a spudger/prying tool. Indications that replacement is necessary include missing keys, unresponsive keys, and possibly delayed typing functions.
Was du brauchst
Using an opening tool, pry open the back panel, starting at the silver screen hinges.
Remove the two Phillips #0 screws holding the battery inside the laptop case.
Using either your hands or a pair of tweezers, carefully pull the battery's cable out of its motherboard port.
Using your hands, lift up on the battery from its slot, and carefully slide it away from you before fully lifting it out of the case.
Loosen the single Phillips #0 screw holding the hard drive in place.
Gently lift the closer side of the hard drive out of its slot.
Make sure not to pull too hard on the cables plugged into the motherboard.
Remove each rubber edge from the hard drive, and reassemble with a new hard drive.
Using your nails or tweezers, unplug the charger port cable from the motherboard.
Lift the three black tabs to release the cable connectors.
After the tabs are lifted, the white cables with blue ends can be pulled out of their slots.
Remove the single Phillips #0 screw.
Unplug the speaker cable.
Unplug the secondary speaker cable.
Use a Phillips #0 screwdriver to remove four screws from the heat sink.
Carefully slide the motherboard from under the heat sink (it is easiest to slide the motherboard to the right).
