Einleitung
The main component of the Acer Spin 3 SP315-51-757C is the motherboard, since it is the central piece of the computer than connects all other parts. A faulty motherboard can be the cause of a large number of problems. Replacing your motherboard should only be your last resort if no other guides fix your computer’s issue.
Was du brauchst
Using an opening tool, pry open the back panel, starting at the silver screen hinges.
Remove the two Phillips #0 screws holding the battery inside the laptop case.
Using your hands, lift up on the battery from its slot, and carefully slide it away from you before fully lifting it out of the case.
Lift the three black tabs to release the cable connectors.
After the tabs are lifted, the white cables with blue ends can be pulled out of their slots.
Remove the single Phillips #0 screw.
Unplug the speaker cable.
Unplug the secondary speaker cable.
Use a Phillips #0 screwdriver to remove four screws from the heat sink.
Carefully slide the motherboard from under the heat sink (it is easiest to slide the motherboard to the right).
4 weitere Personen haben diese Anleitung absolviert.
