Was du brauchst
Using an opening tool, pry open the back panel, starting at the silver screen hinges.
Remove the two Phillips #0 screws holding the battery inside the laptop case.
Using either your hands or a pair of tweezers, carefully pull the battery's cable out of its motherboard port.
Using your hands, lift up on the battery from its slot, and carefully slide it away from you before fully lifting it out of the case.
Using your nails or tweezers, unplug the charger port cable from the motherboard.
Lift the three black tabs to release the cable connectors.
After the tabs are lifted, the white cables with blue ends can be pulled out of their slots.
Remove the single Phillips #0 screw.
Unplug the speaker cable.
Unplug the secondary speaker cable.
Use a Phillips #0 screwdriver to remove four screws from the heat sink.
Carefully slide the motherboard from under the heat sink (it is easiest to slide the motherboard to the right).
Remove the screws from the "L" and "R" plastic pieces using a Phillips #0 screwdriver.
Remove four screws from the metal hinges in the corners using a Phillips #0 screwdriver.
