Zum Hauptinhalt wechseln
Acer Spin 3 SP315-51-757C Trackpad Replacement
Was du brauchst
  1. Acer Spin 3 SP315-51-757C Trackpad Replacement, Back Panel: Schritt 1, Bild 1 von 2 Acer Spin 3 SP315-51-757C Trackpad Replacement, Back Panel: Schritt 1, Bild 2 von 2
    • Remove eleven Phillips #0 screws from the back panel.
  2. Acer Spin 3 SP315-51-757C Trackpad Replacement: Schritt 2, Bild 1 von 3 Acer Spin 3 SP315-51-757C Trackpad Replacement: Schritt 2, Bild 2 von 3 Acer Spin 3 SP315-51-757C Trackpad Replacement: Schritt 2, Bild 3 von 3
    • Using an opening tool, pry open the back panel, starting at the silver screen hinges.
    • You may need to apply more force than usual. If you don't find any success at the hinges, you can try to start at another area that looks easier to open.
    • You can also use some plastic opening picks to help hold parts of the panel open while you work on other sides.
  3. Acer Spin 3 SP315-51-757C Trackpad Replacement: Schritt 3, Bild 1 von 1
    • Lift the back panel off of the laptop.
  4. Acer Spin 3 SP315-51-757C Trackpad Replacement, Battery: Schritt 4, Bild 1 von 2 Acer Spin 3 SP315-51-757C Trackpad Replacement, Battery: Schritt 4, Bild 2 von 2
    • Remove the two Phillips #0 screws holding the battery inside the laptop case.
  5. Acer Spin 3 SP315-51-757C Trackpad Replacement: Schritt 5, Bild 1 von 3 Acer Spin 3 SP315-51-757C Trackpad Replacement: Schritt 5, Bild 2 von 3 Acer Spin 3 SP315-51-757C Trackpad Replacement: Schritt 5, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Using either your hands or a pair of tweezers, carefully pull the battery's cable out of its motherboard port.
  6. Acer Spin 3 SP315-51-757C Trackpad Replacement: Schritt 6, Bild 1 von 1
    • Using your hands, lift up on the battery from its slot, and carefully slide it away from you before fully lifting it out of the case.
  7. Acer Spin 3 SP315-51-757C Trackpad Replacement, Charger Port: Schritt 7, Bild 1 von 1
    Kaufen
    • The charger port's inner cable may be covered by a manufacturer sticker, which can be easily removed.
    • Using your nails or tweezers, unplug the charger port cable from the motherboard.
  8. Acer Spin 3 SP315-51-757C Trackpad Replacement: Schritt 8, Bild 1 von 1
    • Gently lift the charger port out of its slot in the laptop casing.
  9. Acer Spin 3 SP315-51-757C Trackpad Replacement, Motherboard: Schritt 9, Bild 1 von 2 Acer Spin 3 SP315-51-757C Trackpad Replacement, Motherboard: Schritt 9, Bild 2 von 2
    • Lift the three black tabs to release the cable connectors.
    • After the tabs are lifted, the white cables with blue ends can be pulled out of their slots.
  10. Acer Spin 3 SP315-51-757C Trackpad Replacement: Schritt 10, Bild 1 von 3 Acer Spin 3 SP315-51-757C Trackpad Replacement: Schritt 10, Bild 2 von 3 Acer Spin 3 SP315-51-757C Trackpad Replacement: Schritt 10, Bild 3 von 3
    • Remove the cables near the fan by pulling them carefully out of their slots.
  11. Acer Spin 3 SP315-51-757C Trackpad Replacement: Schritt 11, Bild 1 von 3 Acer Spin 3 SP315-51-757C Trackpad Replacement: Schritt 11, Bild 2 von 3 Acer Spin 3 SP315-51-757C Trackpad Replacement: Schritt 11, Bild 3 von 3
    • Remove the single Phillips #0 screw.
    • Unplug the speaker cable.
    • Unplug the secondary speaker cable.
  12. Acer Spin 3 SP315-51-757C Trackpad Replacement: Schritt 12, Bild 1 von 3 Acer Spin 3 SP315-51-757C Trackpad Replacement: Schritt 12, Bild 2 von 3 Acer Spin 3 SP315-51-757C Trackpad Replacement: Schritt 12, Bild 3 von 3
    • Remove the three Phillips #0 screws attached to the motherboard.
  13. Acer Spin 3 SP315-51-757C Trackpad Replacement: Schritt 13, Bild 1 von 2 Acer Spin 3 SP315-51-757C Trackpad Replacement: Schritt 13, Bild 2 von 2
    • Use a Phillips #0 screwdriver to remove four screws from the heat sink.
    • Carefully slide the motherboard from under the heat sink (it is easiest to slide the motherboard to the right).
  14. Acer Spin 3 SP315-51-757C Trackpad Replacement, Heat Sink and Fan: Schritt 14, Bild 1 von 1
    • Using a Phillips #0 screwdriver, remove the three screws that hold the fan on top of the motherboard.
  15. Acer Spin 3 SP315-51-757C Trackpad Replacement: Schritt 15, Bild 1 von 1
    • Using a Phillips #0 screwdriver, remove the four screws that connect the heat sink to the motherboard.
  16. Acer Spin 3 SP315-51-757C Trackpad Replacement: Schritt 16, Bild 1 von 2 Acer Spin 3 SP315-51-757C Trackpad Replacement: Schritt 16, Bild 2 von 2
    • Remove both the fan and the heat sink with your hands.
  17. Acer Spin 3 SP315-51-757C Trackpad Replacement, Hard Drive: Schritt 17, Bild 1 von 2 Acer Spin 3 SP315-51-757C Trackpad Replacement, Hard Drive: Schritt 17, Bild 2 von 2
    • Loosen the single Phillips #0 screw holding the hard drive in place.
  18. Acer Spin 3 SP315-51-757C Trackpad Replacement: Schritt 18, Bild 1 von 2 Acer Spin 3 SP315-51-757C Trackpad Replacement: Schritt 18, Bild 2 von 2
    • Gently lift the closer side of the hard drive out of its slot.
    • Make sure not to pull too hard on the cables plugged into the motherboard.
  19. Acer Spin 3 SP315-51-757C Trackpad Replacement: Schritt 19, Bild 1 von 1
    • Carefully unplug the cable connected to the side of the hard drive.
  20. Acer Spin 3 SP315-51-757C Trackpad Replacement: Schritt 20, Bild 1 von 2 Acer Spin 3 SP315-51-757C Trackpad Replacement: Schritt 20, Bild 2 von 2
    • Remove each rubber edge from the hard drive, and reassemble with a new hard drive.
  21. Acer Spin 3 SP315-51-757C Trackpad Replacement, Keyboard: Schritt 21, Bild 1 von 1
    • Remove the plastic rivets individually using a spudger.
  22. Acer Spin 3 SP315-51-757C Trackpad Replacement: Schritt 22, Bild 1 von 1
    • Swipe a spudger underneath keyboard to unlock it from its frame.
  23. Acer Spin 3 SP315-51-757C Trackpad Replacement: Schritt 23, Bild 1 von 1
    • Use the spudger to pry the keyboard up and away from the laptop.
  24. Acer Spin 3 SP315-51-757C Trackpad Replacement, Trackpad: Schritt 24, Bild 1 von 1
    • Remove all the plastic rivets with a spudger.
  25. Acer Spin 3 SP315-51-757C Trackpad Replacement: Schritt 25, Bild 1 von 1
    • Remove the bottom metal bar with your hands.
  26. Acer Spin 3 SP315-51-757C Trackpad Replacement: Schritt 26, Bild 1 von 1
    • Remove the trackpad by pressing upwards from the bottom.
Abschluss
Kylie Ann
97 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 5
Letzte 30 Tage: 12
Insgesamt: 28
