Einleitung
Is your device overheating or not properly cooling? If so, the fan may be faulty and needs to be replaced. Follow the instructions in this guide to remove and replace the fan in the Acer Spin 3 SP315-51-79NT laptop.
Was du brauchst
Using the Phillips #1 screwdriver, remove twelve (12) screws from the back panel.
Using the Phillips #1 screwdriver, remove two screws securing the fan to the motherboard.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
