Einleitung
The hard drive is the storage component of a laptop or computer. If you’re unable to read files or access files in your computer, your hard drive may be corrupted and needs to be replaced. Use this guide to replace the hard drive in your device.
Was du brauchst
Remove the twelve screws on the back cover using the Phillips #1 screwdriver.
Remove two 4 mm screws at the two corners of the battery using the Phillips #1 screwdriver.
2 Kommentare
You highlighted some random spot for the hard drive but you should have highlighted the empty m.2 slot which doesn’t even require you to remove the battery.
Agreed. This guide is pointless. Just a random, inaccurate guess. Why even bother putting this together if you don't know what you're talking about.
