Zum Hauptinhalt wechseln
Acer Spin 5 N17W2 Motherboard Replacement
Was du brauchst
  1. Acer Spin 5 N17W2 Motherboard Replacement, Cooling Fan: Schritt 1, Bild 1 von 2 Acer Spin 5 N17W2 Motherboard Replacement, Cooling Fan: Schritt 1, Bild 2 von 2
    • Use the Phillips #1 screwdriver to remove six 6 mm screws.
    • Use the same screwdriver to remove six 5mm screws.
  2. Acer Spin 5 N17W2 Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Use an opening tool to pry the back cover open.
  3. Acer Spin 5 N17W2 Motherboard Replacement: Schritt 3, Bild 1 von 1
    • Remove two 5 mm screws by using the Phillips #1 screwdriver.
  4. Acer Spin 5 N17W2 Motherboard Replacement: Schritt 4, Bild 1 von 2 Acer Spin 5 N17W2 Motherboard Replacement: Schritt 4, Bild 2 von 2
    • Use two opening tools to disconnect the cooling fan from the motherboard.
    • Remove the fan from the device.
  5. Acer Spin 5 N17W2 Motherboard Replacement, Motherboard: Schritt 5, Bild 1 von 1
    • Remove four 5 mm screws using the Phillips #1 screwdriver.
  6. Acer Spin 5 N17W2 Motherboard Replacement: Schritt 6, Bild 1 von 1
    • Take off the black heat sink (be careful of the grey thermal grease).
  7. Acer Spin 5 N17W2 Motherboard Replacement: Schritt 7, Bild 1 von 3 Acer Spin 5 N17W2 Motherboard Replacement: Schritt 7, Bild 2 von 3 Acer Spin 5 N17W2 Motherboard Replacement: Schritt 7, Bild 3 von 3
    • Remove all peripherals connecting to the motherboard.
    • Remove the second chip.
    • Remove the wireless LAN chip.
  8. Acer Spin 5 N17W2 Motherboard Replacement: Schritt 8, Bild 1 von 1
    • Disconnect the three connection wires.
  9. Acer Spin 5 N17W2 Motherboard Replacement: Schritt 9, Bild 1 von 2 Acer Spin 5 N17W2 Motherboard Replacement: Schritt 9, Bild 2 von 2
    • Take off the connecting port with black tape.
    • Take off the last port with purple tape.
  10. Acer Spin 5 N17W2 Motherboard Replacement: Schritt 10, Bild 1 von 1
    • Remove the motherboard from the device.
Abschluss
2 Kommentare
I need the motherboard where I can buy it..
john fredy mendoza torres - Antwort
I need the motherboard where I can buy it please...
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 26
Insgesamt: 1,406
