Einleitung
If the laptop powers on with the charger connected, but fails to power on or stay on when disconnected, then your battery may need to be replaced. The battery is responsible for supplying power to your laptop when it is not plugged in to a power outlet. This guide will show you how to replace the battery.
Werkzeuge
Ersatzteile
Keine Ersatzteile angegeben.
Flip your laptop over so that the model sticker is facing upward towards the ceiling.
Use a Phillips #1 screwdriver to remove the thirteen 6.5mm screws that secure the back cover.
Use a plastic opening tool to gently separate the back cover from the laptop. A snapping sound will be heard as a signal that the clips are being disengaged.
Use a Phillips #1 screwdriver to remove two 4 mm screws that secure the battery.
Use your hand to carefully pull out the wiring harness from its port that is located between the battery and the motherboard.
Remove the battery from the case.
2 weitere Nutzer haben diese Anleitung absolviert.
