Einleitung
This battery is responsible for the information about all the system's configuration, such as the hard disk, date and time. When starting your computer you’re constantly having to reset your clock, the date or when the Run Setup screen appears on your screen you need to replace the CMOS battery. Follow this guide to replace your CMOS battery.
Was du brauchst
Flip your laptop over so that the model sticker is facing upward towards the ceiling.
Use a Phillips #1 screwdriver to remove the thirteen 6.5mm screws that secure the back cover.
Use a plastic opening tool to gently separate the back cover from the laptop. A snapping sound will be heard as a signal that the clips are being disengaged.
Use a Phillips #1 screwdriver to remove two 4 mm screws that secure the battery.
Use your hand to carefully pull out the wiring harness from its port that is located between the battery and the motherboard.
Remove the battery from the case.
Eine weitere Person hat diese Anleitung absolviert.
