Zum Hauptinhalt wechseln
Acer Spin 5 SP513-51-57TP Cooling Fan Replacement
Was du brauchst
  1. Acer Spin 5 SP513-51-57TP Cooling Fan Replacement, Battery: Schritt 1, Bild 1 von 1
    • Flip your laptop over so that the model sticker is facing upward towards the ceiling.
    • Make sure your computer is turned off before starting to avoid getting shocked.
  2. Acer Spin 5 SP513-51-57TP Cooling Fan Replacement: Schritt 2, Bild 1 von 2 Acer Spin 5 SP513-51-57TP Cooling Fan Replacement: Schritt 2, Bild 2 von 2
    • Use a Phillips #1 screwdriver to remove the thirteen 6.5mm screws that secure the back cover.
  3. Acer Spin 5 SP513-51-57TP Cooling Fan Replacement: Schritt 3, Bild 1 von 3 Acer Spin 5 SP513-51-57TP Cooling Fan Replacement: Schritt 3, Bild 2 von 3 Acer Spin 5 SP513-51-57TP Cooling Fan Replacement: Schritt 3, Bild 3 von 3
    • Use a plastic opening tool to gently separate the back cover from the laptop. A snapping sound will be heard as a signal that the clips are being disengaged.
    • Do not use any metal tools to pry open the device.
    • It is recommended that you start from one corner and run the tool along the edges of your laptop from corner to corner for a safe removal.
  4. Acer Spin 5 SP513-51-57TP Cooling Fan Replacement: Schritt 4, Bild 1 von 3 Acer Spin 5 SP513-51-57TP Cooling Fan Replacement: Schritt 4, Bild 2 von 3 Acer Spin 5 SP513-51-57TP Cooling Fan Replacement: Schritt 4, Bild 3 von 3
    • Use a Phillips #1 screwdriver to remove two 4 mm screws that secure the battery.
  5. Acer Spin 5 SP513-51-57TP Cooling Fan Replacement: Schritt 5, Bild 1 von 3 Acer Spin 5 SP513-51-57TP Cooling Fan Replacement: Schritt 5, Bild 2 von 3 Acer Spin 5 SP513-51-57TP Cooling Fan Replacement: Schritt 5, Bild 3 von 3
    • Use your hand to carefully pull out the wiring harness from its port that is located between the battery and the motherboard.
    • Remove the battery from the case.
  6. Acer Spin 5 SP513-51-57TP Cooling Fan Replacement, Cooling Fan: Schritt 6, Bild 1 von 3 Acer Spin 5 SP513-51-57TP Cooling Fan Replacement, Cooling Fan: Schritt 6, Bild 2 von 3 Acer Spin 5 SP513-51-57TP Cooling Fan Replacement, Cooling Fan: Schritt 6, Bild 3 von 3
    • Use Phillips #1 screwdriver to remove the two 4mm screws that are securing the fan.
  7. Acer Spin 5 SP513-51-57TP Cooling Fan Replacement: Schritt 7, Bild 1 von 2 Acer Spin 5 SP513-51-57TP Cooling Fan Replacement: Schritt 7, Bild 2 von 2
    • Using Phillips #1 screwdriver remove three 5 mm screws to remove the heatsink.
    • When removing the cooling fan, the heatsink component will stay connected.
  8. Acer Spin 5 SP513-51-57TP Cooling Fan Replacement: Schritt 8, Bild 1 von 3 Acer Spin 5 SP513-51-57TP Cooling Fan Replacement: Schritt 8, Bild 2 von 3 Acer Spin 5 SP513-51-57TP Cooling Fan Replacement: Schritt 8, Bild 3 von 3
    • Using your hand, pull out wiring harness to disconnect the fan from the motherboard.
    • Lift the fan out of the case to remove it.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Anthony Vansell
872 Reputation
5 Anleitungen geschrieben
Hufflepuff Mitglied von Hufflepuff
Meetup
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 5
Letzten 30 Tage: 29
Insgesamt: 1,007
