Zum Hauptinhalt wechseln
Acer Spin 7 SP714-51 Keyboard Replacement
Was du brauchst
  1. Acer Spin 7 SP714-51 Keyboard Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn the laptop so that the back cover is visible and facing you. Make sure it is on a flat surface such as a table.
    • Use a Phillips #0 screwdriver to remove the 6 mm screws along the edge of the bottom cover.
  2. Acer Spin 7 SP714-51 Keyboard Replacement: Schritt 2, Bild 1 von 1
    • Once all the screws are removed, you should easily be able to remove the back cover. This can be done by hand or by using a Spudger as seen in the tools list.
  3. Acer Spin 7 SP714-51 Keyboard Replacement: Schritt 3, Bild 1 von 2 Acer Spin 7 SP714-51 Keyboard Replacement: Schritt 3, Bild 2 von 2
    • Remove the battery connector cable from the motherboard.
    • This will cut power to the laptop, reducing the likelihood of damage and injury.
    • Ensure that you are pulling the connector straight back, if you pull up at all you may damage the battery connector on the motherboard.
  4. Acer Spin 7 SP714-51 Keyboard Replacement: Schritt 4, Bild 1 von 2 Acer Spin 7 SP714-51 Keyboard Replacement: Schritt 4, Bild 2 von 2
    • Use a Phillips #0 screwdriver to remove the last two 3mm long fasteners at the edge of the laptop body, and carefully remove the battery.
    • Place the new battery in the battery slot
    • Do not bend or puncture the battery.
  5. Acer Spin 7 SP714-51 Keyboard Replacement, Keyboard: Schritt 5, Bild 1 von 3 Acer Spin 7 SP714-51 Keyboard Replacement, Keyboard: Schritt 5, Bild 2 von 3 Acer Spin 7 SP714-51 Keyboard Replacement, Keyboard: Schritt 5, Bild 3 von 3
    • Disconnect the white and black antennae from the Wi-Fi card, located on the left side of the laptop. The antennae should snap off upwards easily with a pry tool.
    • Unscrew the retaining screw from the Wi-Fi card and unslot the card to remove it from the laptop.
  6. Acer Spin 7 SP714-51 Keyboard Replacement: Schritt 6, Bild 1 von 3 Acer Spin 7 SP714-51 Keyboard Replacement: Schritt 6, Bild 2 von 3 Acer Spin 7 SP714-51 Keyboard Replacement: Schritt 6, Bild 3 von 3
    • Lift the tab on the ribbon connector connecting the motherboard to the power switchboard and slide out the connector.
    • Remove the 2 screws holding the switchboard in place and remove the switch panel.
  7. Acer Spin 7 SP714-51 Keyboard Replacement: Schritt 7, Bild 1 von 3 Acer Spin 7 SP714-51 Keyboard Replacement: Schritt 7, Bild 2 von 3 Acer Spin 7 SP714-51 Keyboard Replacement: Schritt 7, Bild 3 von 3
    • Flip up the tab on the keyboard connector and disconnect the ribbon cable from the motherboard.
  8. Acer Spin 7 SP714-51 Keyboard Replacement: Schritt 8, Bild 1 von 3 Acer Spin 7 SP714-51 Keyboard Replacement: Schritt 8, Bild 2 von 3 Acer Spin 7 SP714-51 Keyboard Replacement: Schritt 8, Bild 3 von 3
    • Remove the display connector by lifting the tape and pulling the connector straight back.
    • Remove the trackpad ribbon cable.
    • Remove the speaker connectors, lifting the tape and pulling straight back from the connector.
  9. Acer Spin 7 SP714-51 Keyboard Replacement: Schritt 9, Bild 1 von 1
    • Remove the touchscreen connector after peeling up the adhesive tape holding it in place.
    • Make sure to pull straight back to avoid damaging the connector.
  10. Acer Spin 7 SP714-51 Keyboard Replacement: Schritt 10, Bild 1 von 2 Acer Spin 7 SP714-51 Keyboard Replacement: Schritt 10, Bild 2 von 2
    • On the upper left side of the back panel is a protective shield for the USB-C panel. Remove the two 3mm screws holding the panel in place using the PH0 Phillips head screwdriver.
    • Gently pull the panel away being careful not to damage anything.
  11. Acer Spin 7 SP714-51 Keyboard Replacement: Schritt 11, Bild 1 von 2 Acer Spin 7 SP714-51 Keyboard Replacement: Schritt 11, Bild 2 von 2
    • Unscrew the silver 3mm long screws holding the motherboard using the PH0 bit and remove them carefully to avoid breaking them.
    • This will allow the user to get to the keyboard without any other parts in the way making it easier to work with.
  12. Acer Spin 7 SP714-51 Keyboard Replacement: Schritt 12, Bild 1 von 1
    • Partially covering the keyboard is a heatsink, grab the two edges as seen in the photo.
    • Carefully pull away the heatsink to gain access to the keyboard.
  13. Acer Spin 7 SP714-51 Keyboard Replacement: Schritt 13, Bild 1 von 3 Acer Spin 7 SP714-51 Keyboard Replacement: Schritt 13, Bild 2 von 3 Acer Spin 7 SP714-51 Keyboard Replacement: Schritt 13, Bild 3 von 3
    • Use a Phillips #000 screwdriver to remove the 2 mm screws that secure the keyboard in place, and carefully remove the keyboard to avoid breaking it.
Abschluss
UMass Dartmouth, Team 7-3, Sinclaire Spring 2022 Mitglied von UMass Dartmouth, Team 7-3, Sinclaire Spring 2022
UMASSD-SINCLAIRE-S22S7G3
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 11
Insgesamt: 428
