Zum Hauptinhalt wechseln
Acer TravelMate P653-V-6882 Keyboard Replacement
Was du brauchst
  1. Acer TravelMate P653-V-6882 Keyboard Replacement, Battery Pack: Schritt 1, Bild 1 von 2 Acer TravelMate P653-V-6882 Keyboard Replacement, Battery Pack: Schritt 1, Bild 2 von 2
    • Turn the computer over so the base is facing up.
    • Slide the battery lock to unlock position.
    Frag FixBot
    Kommentar hinzufügen
  2. Acer TravelMate P653-V-6882 Keyboard Replacement: Schritt 2, Bild 1 von 1
    • Slide the battery release latch to the right.
    • The battery pack will pop out.
    Frag FixBot
  3. Acer TravelMate P653-V-6882 Keyboard Replacement: Schritt 3, Bild 1 von 1
    • Lift the battery up.
    • Pull out the battery.
    Frag FixBot
  4. Acer TravelMate P653-V-6882 Keyboard Replacement, Base Door: Schritt 4, Bild 1 von 1
    • Remove the five 7mm Phillips #1 screws.
    Frag FixBot
  5. Acer TravelMate P653-V-6882 Keyboard Replacement: Schritt 5, Bild 1 von 1
    • Use the opening tool to separate base door from the bottom of the laptop.
    • Be careful not to bend or crack the plastic back cover.
    Frag FixBot
  6. Acer TravelMate P653-V-6882 Keyboard Replacement: Schritt 6, Bild 1 von 2 Acer TravelMate P653-V-6882 Keyboard Replacement: Schritt 6, Bild 2 von 2
    • Gently pry open the base door by pushing up.
    • Pull out the base door.
    Frag FixBot
  7. Acer TravelMate P653-V-6882 Keyboard Replacement, Keyboard: Schritt 7, Bild 1 von 1
    • Remove the two 7mm Phillips #1 screws.
    Frag FixBot
  8. Acer TravelMate P653-V-6882 Keyboard Replacement: Schritt 8, Bild 1 von 1
    • Flip the laptop so that the underside is now facing the bottom.
    • Open the LCD panel.
    • Use the flat end of a spudger to push in the six latches.
    • Be careful not to bend or crack the keyboard.
    Frag FixBot
  9. Acer TravelMate P653-V-6882 Keyboard Replacement: Schritt 9, Bild 1 von 1
    • When the latches are pushed in, the keyboard will pop out.
    • Gently pry up the keyboard.
    Frag FixBot
  10. Acer TravelMate P653-V-6882 Keyboard Replacement: Schritt 10, Bild 1 von 1
    • Slide the keyboard forward to access the keyboard cable.
    • Flip the connector latch up to open it.
    • Pull out the keyboard cable gently.
    • Be careful not to damage the connector.
    Frag FixBot
Abschluss
York University, Team S1-G6, Woodhouse Winter 2020 Mitglied von York University, Team S1-G6, Woodhouse Winter 2020
YORK-WOODHOUSE-W20S1G6
3 Mitglieder
9 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 8
Letzte 30 Tage: 33
Insgesamt: 844
