Zum Hauptinhalt wechseln
Acer TravelMate P653-V-6882 LCD Module Replacement
Was du brauchst
  1. Acer TravelMate P653-V-6882 LCD Module Replacement, Battery Pack: Schritt 1, Bild 1 von 2 Acer TravelMate P653-V-6882 LCD Module Replacement, Battery Pack: Schritt 1, Bild 2 von 2
    • Turn the computer over so the base is facing up.
    • Slide the battery lock to unlock position.
  2. Acer TravelMate P653-V-6882 LCD Module Replacement: Schritt 2, Bild 1 von 1
    • Slide the battery release latch to the right.
    • The battery pack will pop out.
  3. Acer TravelMate P653-V-6882 LCD Module Replacement: Schritt 3, Bild 1 von 1
    • Lift the battery up.
    • Pull out the battery.
  4. Acer TravelMate P653-V-6882 LCD Module Replacement, ODD Module: Schritt 4, Bild 1 von 1
    • Slide the ODD module latch down.
    • The ODD module will pop out.
  5. Acer TravelMate P653-V-6882 LCD Module Replacement: Schritt 5, Bild 1 von 1
    • Remove the ODD module.
  6. Acer TravelMate P653-V-6882 LCD Module Replacement, Base Door: Schritt 6, Bild 1 von 1
    • Remove the five 7mm Phillips #1 screws.
  7. Acer TravelMate P653-V-6882 LCD Module Replacement: Schritt 7, Bild 1 von 1
    • Use the opening tool to separate base door from the bottom of the laptop.
    • Be careful not to bend or crack the plastic back cover.
  8. Acer TravelMate P653-V-6882 LCD Module Replacement: Schritt 8, Bild 1 von 2 Acer TravelMate P653-V-6882 LCD Module Replacement: Schritt 8, Bild 2 von 2
    • Gently pry open the base door by pushing up.
    • Pull out the base door.
  9. Acer TravelMate P653-V-6882 LCD Module Replacement, Keyboard: Schritt 9, Bild 1 von 1
    • Remove the two 7mm Phillips #1 screws.
  10. Acer TravelMate P653-V-6882 LCD Module Replacement: Schritt 10, Bild 1 von 1
    • Flip the laptop so that the underside is now facing the bottom.
    • Open the LCD panel.
    • Use the flat end of a spudger to push in the six latches.
    • Be careful not to bend or crack the keyboard.
  11. Acer TravelMate P653-V-6882 LCD Module Replacement: Schritt 11, Bild 1 von 1
    • When the latches are pushed in, the keyboard will pop out.
    • Gently pry up the keyboard.
  12. Acer TravelMate P653-V-6882 LCD Module Replacement: Schritt 12, Bild 1 von 1
    • Slide the keyboard forward to access the keyboard cable.
    • Flip the connector latch up to open it.
    • Pull out the keyboard cable gently.
    • Be careful not to damage the connector.
  13. Acer TravelMate P653-V-6882 LCD Module Replacement, Mainboard: Schritt 13, Bild 1 von 3 Acer TravelMate P653-V-6882 LCD Module Replacement, Mainboard: Schritt 13, Bild 2 von 3 Acer TravelMate P653-V-6882 LCD Module Replacement, Mainboard: Schritt 13, Bild 3 von 3
    • Turn the computer over, open the LCD panel, and find the smart card cable connector.
    • Open the smart card cable connector latch.
    • Disconnect the cable.
  14. Acer TravelMate P653-V-6882 LCD Module Replacement: Schritt 14, Bild 1 von 3 Acer TravelMate P653-V-6882 LCD Module Replacement: Schritt 14, Bild 2 von 3 Acer TravelMate P653-V-6882 LCD Module Replacement: Schritt 14, Bild 3 von 3
    • Find the power button launch board cable connector.
    • Open the power button launch board cable connector latch.
  15. Acer TravelMate P653-V-6882 LCD Module Replacement: Schritt 15, Bild 1 von 3 Acer TravelMate P653-V-6882 LCD Module Replacement: Schritt 15, Bild 2 von 3 Acer TravelMate P653-V-6882 LCD Module Replacement: Schritt 15, Bild 3 von 3
    • Find the touchpad and fingerprint board cable connector.
    • Open the touchpad and fingerprint board cable connector’s latches.
    • Disconnect the cables.
  16. Acer TravelMate P653-V-6882 LCD Module Replacement: Schritt 16, Bild 1 von 1
    • Using the #1 Phillips screwdriver, remove the two screws.
  17. Acer TravelMate P653-V-6882 LCD Module Replacement: Schritt 17, Bild 1 von 1
    • Flip the laptop over so that the underside is facing up.
    • Remove the twelve 7mm Phillips #1 screws.
    • Remove the five 3mm Phillips #1 screws.
    • Disconnect the cables connecting to the WLAN module.
  18. Acer TravelMate P653-V-6882 LCD Module Replacement: Schritt 18, Bild 1 von 3 Acer TravelMate P653-V-6882 LCD Module Replacement: Schritt 18, Bild 2 von 3 Acer TravelMate P653-V-6882 LCD Module Replacement: Schritt 18, Bild 3 von 3
    • Locate the small gaps between the upper cover and lower case on the left and right side of the laptop.
    • Insert the opening tool into each gap to separate the one from the other.
    • Once the upper cover is separated, lift it from the lower case.
    • Be careful not to damage the upper and lower case while removing.
  19. Acer TravelMate P653-V-6882 LCD Module Replacement: Schritt 19, Bild 1 von 3 Acer TravelMate P653-V-6882 LCD Module Replacement: Schritt 19, Bild 2 von 3 Acer TravelMate P653-V-6882 LCD Module Replacement: Schritt 19, Bild 3 von 3
    • Detach the transparent tape securing the LCD cable.
    • Disconnect the LCD cable from the mainboard.
    • Be careful not to damage the LCD cable connector.
  20. Acer TravelMate P653-V-6882 LCD Module Replacement: Schritt 20, Bild 1 von 3 Acer TravelMate P653-V-6882 LCD Module Replacement: Schritt 20, Bild 2 von 3 Acer TravelMate P653-V-6882 LCD Module Replacement: Schritt 20, Bild 3 von 3
    • Detach the black tape covering the microphone cable.
    • Disconnect the microphone cable from the mainboard.
  21. Acer TravelMate P653-V-6882 LCD Module Replacement: Schritt 21, Bild 1 von 3 Acer TravelMate P653-V-6882 LCD Module Replacement: Schritt 21, Bild 2 von 3 Acer TravelMate P653-V-6882 LCD Module Replacement: Schritt 21, Bild 3 von 3
    • Open the USB board cable's connector latches.
    • Be careful not to damage the connectors.
  22. Acer TravelMate P653-V-6882 LCD Module Replacement: Schritt 22, Bild 1 von 3 Acer TravelMate P653-V-6882 LCD Module Replacement: Schritt 22, Bild 2 von 3 Acer TravelMate P653-V-6882 LCD Module Replacement: Schritt 22, Bild 3 von 3
    • Disconnect the left speaker cable from the mainboard.
  23. Acer TravelMate P653-V-6882 LCD Module Replacement: Schritt 23, Bild 1 von 1
    • Remove the one 7mm Phillips #1 screw.
  24. Acer TravelMate P653-V-6882 LCD Module Replacement: Schritt 24, Bild 1 von 2 Acer TravelMate P653-V-6882 LCD Module Replacement: Schritt 24, Bild 2 von 2
    • Lift the mainboard at an angle and gently turn it on its side.
    • Disconnect the LAN cable from the mainboard.
  25. Acer TravelMate P653-V-6882 LCD Module Replacement, LCD Module: Schritt 25, Bild 1 von 3 Acer TravelMate P653-V-6882 LCD Module Replacement, LCD Module: Schritt 25, Bild 2 von 3 Acer TravelMate P653-V-6882 LCD Module Replacement, LCD Module: Schritt 25, Bild 3 von 3
    • Carefully remove the two pieces of black tape securing the antenna cables to the lower case using tweezers.
  26. Acer TravelMate P653-V-6882 LCD Module Replacement: Schritt 26, Bild 1 von 1
    • Release the white antenna cable from its top side latches.
    • Be careful not to damage the cable.
  27. Acer TravelMate P653-V-6882 LCD Module Replacement: Schritt 27, Bild 1 von 1
    • Release the black antenna cable from its top side latches.
  28. Acer TravelMate P653-V-6882 LCD Module Replacement: Schritt 28, Bild 1 von 1
    • Make sure to hold onto the LCD module when removing the screws as the display may fall back.
  29. Acer TravelMate P653-V-6882 LCD Module Replacement: Schritt 29, Bild 1 von 1
    • Carefully remove the LCD module from the lower case.
Abschluss
York University, Team S1-G6, Woodhouse Winter 2020 Mitglied von York University, Team S1-G6, Woodhouse Winter 2020
YORK-WOODHOUSE-W20S1G6
3 Mitglieder
9 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 4
Letzte 30 Tage: 7
Insgesamt: 348
