Einleitung
Sometimes the RAM in a device will slow down over time. If your Acer TravelMate P653-V-6882 is being exceptionally slow, you may need to replace the RAM. This will help your device function better and increase its ability to multi task.
Ensure that the device is fully powered off before following the steps below.
Was du brauchst
Turn the computer over so the base is facing up.
Slide the battery lock to unlock position.
Pinch the two metal pieces holding the RAM sticks in place outwards.
Holding the sides of the RAM, slide the RAM sticks out.
