Zum Hauptinhalt wechseln
Acer TravelMate P653-V-6882 RAM Replacement
Was du brauchst
    1. Acer TravelMate P653-V-6882 RAM Replacement, Battery Pack: Schritt 1, Bild 1 von 2 Acer TravelMate P653-V-6882 RAM Replacement, Battery Pack: Schritt 1, Bild 2 von 2
      • Turn the computer over so the base is facing up.
      • Slide the battery lock to unlock position.
      Frag FixBot
      Kommentar hinzufügen
    2. Acer TravelMate P653-V-6882 RAM Replacement: Schritt 2, Bild 1 von 1
      • Slide the battery release latch to the right.
      • The battery pack will pop out.
      Frag FixBot
    3. Acer TravelMate P653-V-6882 RAM Replacement: Schritt 3, Bild 1 von 1
      • Lift the battery up.
      • Pull out the battery.
      Frag FixBot
    1. Acer TravelMate P653-V-6882 RAM Replacement, Base Door: Schritt 4, Bild 1 von 1
      • Remove the five 7mm Phillips #1 screws.
      Frag FixBot
    2. Acer TravelMate P653-V-6882 RAM Replacement: Schritt 5, Bild 1 von 1
      • Use the opening tool to separate base door from the bottom of the laptop.
      • Be careful not to bend or crack the plastic back cover.
      Frag FixBot
    3. Acer TravelMate P653-V-6882 RAM Replacement: Schritt 6, Bild 1 von 2 Acer TravelMate P653-V-6882 RAM Replacement: Schritt 6, Bild 2 von 2
      • Gently pry open the base door by pushing up.
      • Pull out the base door.
      Frag FixBot
    1. Acer TravelMate P653-V-6882 RAM Replacement, RAM: Schritt 7, Bild 1 von 1
      • Locate the two RAM sticks on the bottom of the laptop.
      Frag FixBot
    2. Acer TravelMate P653-V-6882 RAM Replacement: Schritt 8, Bild 1 von 3 Acer TravelMate P653-V-6882 RAM Replacement: Schritt 8, Bild 2 von 3 Acer TravelMate P653-V-6882 RAM Replacement: Schritt 8, Bild 3 von 3
      • Pinch the two metal pieces holding the RAM sticks in place outwards.
      • Holding the sides of the RAM, slide the RAM sticks out.
      • Be careful not to touch the gold connection pins on the RAM sticks, as this could damage the RAM
      Frag FixBot
Abschluss
Basel Kandil
85 Reputation
1 Anleitung geschrieben
York University, Team S1-G6, Woodhouse Winter 2020 Mitglied von York University, Team S1-G6, Woodhouse Winter 2020
YORK-WOODHOUSE-W20S1G6
3 Mitglieder
81 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 24
Insgesamt: 604
