Zum Hauptinhalt wechseln
Acer TravelMate P653-V-6882 Thermal Module Replacement
Was du brauchst
    1. Acer TravelMate P653-V-6882 Thermal Module Replacement, Battery Pack: Schritt 1, Bild 1 von 2 Acer TravelMate P653-V-6882 Thermal Module Replacement, Battery Pack: Schritt 1, Bild 2 von 2
      • Turn the computer over so the base is facing up.
      • Slide the battery lock to unlock position.
      Frag FixBot
      Kommentar hinzufügen
    2. Acer TravelMate P653-V-6882 Thermal Module Replacement: Schritt 2, Bild 1 von 1
      • Slide the battery release latch to the right.
      • The battery pack will pop out.
      Frag FixBot
    3. Acer TravelMate P653-V-6882 Thermal Module Replacement: Schritt 3, Bild 1 von 1
      • Lift the battery up.
      • Pull out the battery.
      Frag FixBot
    1. Acer TravelMate P653-V-6882 Thermal Module Replacement, ODD Module: Schritt 4, Bild 1 von 1
      • Slide the ODD module latch down.
      • The ODD module will pop out.
      Frag FixBot
    2. Acer TravelMate P653-V-6882 Thermal Module Replacement: Schritt 5, Bild 1 von 1
      • Remove the ODD module.
      Frag FixBot
    1. Acer TravelMate P653-V-6882 Thermal Module Replacement, Base Door: Schritt 6, Bild 1 von 1
      • Remove the five 7mm Phillips #1 screws.
      Frag FixBot
    2. Acer TravelMate P653-V-6882 Thermal Module Replacement: Schritt 7, Bild 1 von 1
      • Use the opening tool to separate base door from the bottom of the laptop.
      • Be careful not to bend or crack the plastic back cover.
      Frag FixBot
    3. Acer TravelMate P653-V-6882 Thermal Module Replacement: Schritt 8, Bild 1 von 2 Acer TravelMate P653-V-6882 Thermal Module Replacement: Schritt 8, Bild 2 von 2
      • Gently pry open the base door by pushing up.
      • Pull out the base door.
      Frag FixBot
    1. Acer TravelMate P653-V-6882 Thermal Module Replacement, Keyboard: Schritt 9, Bild 1 von 1
      • Remove the two 7mm Phillips #1 screws.
      Frag FixBot
    2. Acer TravelMate P653-V-6882 Thermal Module Replacement: Schritt 10, Bild 1 von 1
      • Flip the laptop so that the underside is now facing the bottom.
      • Open the LCD panel.
      • Use the flat end of a spudger to push in the six latches.
      • Be careful not to bend or crack the keyboard.
      Frag FixBot
    3. Acer TravelMate P653-V-6882 Thermal Module Replacement: Schritt 11, Bild 1 von 1
      • When the latches are pushed in, the keyboard will pop out.
      • Gently pry up the keyboard.
      Frag FixBot
    4. Acer TravelMate P653-V-6882 Thermal Module Replacement: Schritt 12, Bild 1 von 1
      • Slide the keyboard forward to access the keyboard cable.
      • Flip the connector latch up to open it.
      • Pull out the keyboard cable gently.
      • Be careful not to damage the connector.
      Frag FixBot
    1. Acer TravelMate P653-V-6882 Thermal Module Replacement, Mainboard: Schritt 13, Bild 1 von 3 Acer TravelMate P653-V-6882 Thermal Module Replacement, Mainboard: Schritt 13, Bild 2 von 3 Acer TravelMate P653-V-6882 Thermal Module Replacement, Mainboard: Schritt 13, Bild 3 von 3
      • Turn the computer over, open the LCD panel, and find the smart card cable connector.
      • Open the smart card cable connector latch.
      • Disconnect the cable.
      Frag FixBot
    2. Acer TravelMate P653-V-6882 Thermal Module Replacement: Schritt 14, Bild 1 von 3 Acer TravelMate P653-V-6882 Thermal Module Replacement: Schritt 14, Bild 2 von 3 Acer TravelMate P653-V-6882 Thermal Module Replacement: Schritt 14, Bild 3 von 3
      • Find the power button launch board cable connector.
      • Open the power button launch board cable connector latch.
      Frag FixBot
    3. Acer TravelMate P653-V-6882 Thermal Module Replacement: Schritt 15, Bild 1 von 3 Acer TravelMate P653-V-6882 Thermal Module Replacement: Schritt 15, Bild 2 von 3 Acer TravelMate P653-V-6882 Thermal Module Replacement: Schritt 15, Bild 3 von 3
      • Find the touchpad and fingerprint board cable connector.
      • Open the touchpad and fingerprint board cable connector’s latches.
      • Disconnect the cables.
      Frag FixBot
    4. Acer TravelMate P653-V-6882 Thermal Module Replacement: Schritt 16, Bild 1 von 1
      • Using the #1 Phillips screwdriver, remove the two screws.
      Frag FixBot
    5. Acer TravelMate P653-V-6882 Thermal Module Replacement: Schritt 17, Bild 1 von 1
      • Flip the laptop over so that the underside is facing up.
      • Remove the twelve 7mm Phillips #1 screws.
      • Remove the five 3mm Phillips #1 screws.
      • Disconnect the cables connecting to the WLAN module.
      Frag FixBot
    6. Acer TravelMate P653-V-6882 Thermal Module Replacement: Schritt 18, Bild 1 von 3 Acer TravelMate P653-V-6882 Thermal Module Replacement: Schritt 18, Bild 2 von 3 Acer TravelMate P653-V-6882 Thermal Module Replacement: Schritt 18, Bild 3 von 3
      • Locate the small gaps between the upper cover and lower case on the left and right side of the laptop.
      • Insert the opening tool into each gap to separate the one from the other.
      • Once the upper cover is separated, lift it from the lower case.
      • Be careful not to damage the upper and lower case while removing.
      Frag FixBot
    7. Acer TravelMate P653-V-6882 Thermal Module Replacement: Schritt 19, Bild 1 von 3 Acer TravelMate P653-V-6882 Thermal Module Replacement: Schritt 19, Bild 2 von 3 Acer TravelMate P653-V-6882 Thermal Module Replacement: Schritt 19, Bild 3 von 3
      • Detach the transparent tape securing the LCD cable.
      • Disconnect the LCD cable from the mainboard.
      • Be careful not to damage the LCD cable connector.
      Frag FixBot
    8. Acer TravelMate P653-V-6882 Thermal Module Replacement: Schritt 20, Bild 1 von 3 Acer TravelMate P653-V-6882 Thermal Module Replacement: Schritt 20, Bild 2 von 3 Acer TravelMate P653-V-6882 Thermal Module Replacement: Schritt 20, Bild 3 von 3
      • Detach the black tape covering the microphone cable.
      • Disconnect the microphone cable from the mainboard.
      Frag FixBot
    9. Acer TravelMate P653-V-6882 Thermal Module Replacement: Schritt 21, Bild 1 von 3 Acer TravelMate P653-V-6882 Thermal Module Replacement: Schritt 21, Bild 2 von 3 Acer TravelMate P653-V-6882 Thermal Module Replacement: Schritt 21, Bild 3 von 3
      • Open the USB board cable's connector latches.
      • Be careful not to damage the connectors.
      Frag FixBot
    10. Acer TravelMate P653-V-6882 Thermal Module Replacement: Schritt 22, Bild 1 von 3 Acer TravelMate P653-V-6882 Thermal Module Replacement: Schritt 22, Bild 2 von 3 Acer TravelMate P653-V-6882 Thermal Module Replacement: Schritt 22, Bild 3 von 3
      • Disconnect the left speaker cable from the mainboard.
      Frag FixBot
    11. Acer TravelMate P653-V-6882 Thermal Module Replacement: Schritt 23, Bild 1 von 1
      • Remove the one 7mm Phillips #1 screw.
      Frag FixBot
    12. Acer TravelMate P653-V-6882 Thermal Module Replacement: Schritt 24, Bild 1 von 2 Acer TravelMate P653-V-6882 Thermal Module Replacement: Schritt 24, Bild 2 von 2
      • Lift the mainboard at an angle and gently turn it on its side.
      • Disconnect the LAN cable from the mainboard.
      Frag FixBot
    1. Acer TravelMate P653-V-6882 Thermal Module Replacement, Thermal Module: Schritt 25, Bild 1 von 2 Acer TravelMate P653-V-6882 Thermal Module Replacement, Thermal Module: Schritt 25, Bild 2 von 2
      • Disconnect the thermal module fan cable from the mainboard by pulling the cable directly upwards.
      Frag FixBot
    2. Acer TravelMate P653-V-6882 Thermal Module Replacement: Schritt 26, Bild 1 von 1
      • Loosen the three spring loaded Phillips #1 screws.
      Frag FixBot
    3. Acer TravelMate P653-V-6882 Thermal Module Replacement: Schritt 27, Bild 1 von 2 Acer TravelMate P653-V-6882 Thermal Module Replacement: Schritt 27, Bild 2 von 2
      • Lift the thermal module directly upwards
      Frag FixBot
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
York University, Team S1-G6, Woodhouse Winter 2020 Mitglied von York University, Team S1-G6, Woodhouse Winter 2020
YORK-WOODHOUSE-W20S1G6
3 Mitglieder
108 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 12
Letzte 30 Tage: 39
Insgesamt: 680
