Einleitung
If your laptop is experiencing internal communication issues, use this guide to remove and replace your motherboard.
Was du brauchst
Remove the thirteen 6mm Phillips screws using the #0 screwdriver.
Remove the back of the laptop.
Remove one 6mm Phillips screw from the Wi-Fi interface using the #0 screwdriver.
Remove the eight 7mm Phillips screws from the motherboard using the #0 screwdriver.
Eine weitere Person hat diese Anleitung absolviert.
