Einleitung
If your laptop screen is consistently freezing or completely unresponsive, use this guide to remove and replace the screen.
Was du brauchst
Remove the thirteen 6mm Phillips screws using the #0 screwdriver.
Remove the back of the laptop.
Use the metal spudger to pry open the front plastic cover of the screen.
Take off the front plastic cover then remove four 6mm Phillips screws using the #0 screwdriver.
Fast fertig!
Abschluss
