Zum Hauptinhalt wechseln
Acer TravelMate TMB115-M-C99B Touchpad Replacement
Was du brauchst
  1. Acer TravelMate TMB115-M-C99B Touchpad Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn off your laptop before starting.
    • Flip the laptop over so the model stickers face the ceiling.
  2. Acer TravelMate TMB115-M-C99B Touchpad Replacement: Schritt 2, Bild 1 von 3 Acer TravelMate TMB115-M-C99B Touchpad Replacement: Schritt 2, Bild 2 von 3 Acer TravelMate TMB115-M-C99B Touchpad Replacement: Schritt 2, Bild 3 von 3
    • Remove the thirteen 6mm Phillips screws using the #0 screwdriver.
    • Remove the back of the laptop.
  3. Acer TravelMate TMB115-M-C99B Touchpad Replacement: Schritt 3, Bild 1 von 1
    • Remove the two 7mm Phillips screws from the battery using the #0 screwdriver.
  4. Acer TravelMate TMB115-M-C99B Touchpad Replacement: Schritt 4, Bild 1 von 2 Acer TravelMate TMB115-M-C99B Touchpad Replacement: Schritt 4, Bild 2 von 2
    • Unplug the battery from the motherboard.
  5. Acer TravelMate TMB115-M-C99B Touchpad Replacement, Hard Drive: Schritt 5, Bild 1 von 3 Acer TravelMate TMB115-M-C99B Touchpad Replacement, Hard Drive: Schritt 5, Bild 2 von 3 Acer TravelMate TMB115-M-C99B Touchpad Replacement, Hard Drive: Schritt 5, Bild 3 von 3
    • Carefully disconnect the hard drive from the motherboard.
  6. Acer TravelMate TMB115-M-C99B Touchpad Replacement, Motherboard: Schritt 6, Bild 1 von 1
    • Disconnect the two wires from the Wi-Fi interface.
  7. Acer TravelMate TMB115-M-C99B Touchpad Replacement: Schritt 7, Bild 1 von 2 Acer TravelMate TMB115-M-C99B Touchpad Replacement: Schritt 7, Bild 2 von 2
    • Remove one 6mm Phillips screw from the Wi-Fi interface using the #0 screwdriver.
  8. Acer TravelMate TMB115-M-C99B Touchpad Replacement: Schritt 8, Bild 1 von 1
    • Remove the Wi-Fi interface from the motherboard.
  9. Acer TravelMate TMB115-M-C99B Touchpad Replacement: Schritt 9, Bild 1 von 2 Acer TravelMate TMB115-M-C99B Touchpad Replacement: Schritt 9, Bild 2 von 2
    • Remove the eight 7mm Phillips screws from the motherboard using the #0 screwdriver.
  10. Acer TravelMate TMB115-M-C99B Touchpad Replacement: Schritt 10, Bild 1 von 2 Acer TravelMate TMB115-M-C99B Touchpad Replacement: Schritt 10, Bild 2 von 2
    • Remove the motherboard.
  11. Acer TravelMate TMB115-M-C99B Touchpad Replacement, Touchpad: Schritt 11, Bild 1 von 1
    • Remove one 6mm Phillips screw from the middle of the touchpad with the #0 screwdriver.
  12. Acer TravelMate TMB115-M-C99B Touchpad Replacement: Schritt 12, Bild 1 von 2 Acer TravelMate TMB115-M-C99B Touchpad Replacement: Schritt 12, Bild 2 von 2
    • Remove the wire from the slot.
  13. Acer TravelMate TMB115-M-C99B Touchpad Replacement: Schritt 13, Bild 1 von 1
    • Remove the stickers from the touchpad frame.
  14. Acer TravelMate TMB115-M-C99B Touchpad Replacement: Schritt 14, Bild 1 von 1
    • Remove one 6mm screw from the corner of the touchpad frame with the #0 screwdriver.
  15. Acer TravelMate TMB115-M-C99B Touchpad Replacement: Schritt 15, Bild 1 von 2 Acer TravelMate TMB115-M-C99B Touchpad Replacement: Schritt 15, Bild 2 von 2
    • Lift up the touchpad frame.
  16. Acer TravelMate TMB115-M-C99B Touchpad Replacement: Schritt 16, Bild 1 von 1
    • Remove the touchpad.
Abschluss
Tanvi Kharkar
334 Reputation
2 Anleitungen geschrieben
Cal Poly, Team S1-G5, White Winter 2019 Mitglied von Cal Poly, Team S1-G5, White Winter 2019
CPSU-WHITE-W19S1G5
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 474
