Zum Hauptinhalt wechseln
Acer Travelmate 220 RAM Replacement
Was du brauchst
  1. Acer Travelmate 220 RAM Replacement, RAM Chip: Schritt 1, Bild 1 von 1
    • Place the computer with the bottom facing up.
  2. Acer Travelmate 220 RAM Replacement: Schritt 2, Bild 1 von 3 Acer Travelmate 220 RAM Replacement: Schritt 2, Bild 2 von 3 Acer Travelmate 220 RAM Replacement: Schritt 2, Bild 3 von 3
    • Locate the larger cover panel in the upper left hand corner of the computer.
    • Locate the Phillips screw holding the large cover panel in place.
  3. Acer Travelmate 220 RAM Replacement: Schritt 3, Bild 1 von 2 Acer Travelmate 220 RAM Replacement: Schritt 3, Bild 2 von 2
    • Remove the located screw with the Phillips #00 screwdriver.
  4. Acer Travelmate 220 RAM Replacement: Schritt 4, Bild 1 von 1
    • Slide the large cover panel to the right, until you hear a click.
  5. Acer Travelmate 220 RAM Replacement: Schritt 5, Bild 1 von 2 Acer Travelmate 220 RAM Replacement: Schritt 5, Bild 2 von 2
    • Place the plastic opening tool in the gap created to the left of the large cover panel.
    • Pry the cover panel up and remove it from the computer.
  6. Acer Travelmate 220 RAM Replacement: Schritt 6, Bild 1 von 2 Acer Travelmate 220 RAM Replacement: Schritt 6, Bild 2 von 2
    • Locate the white plastic levers on each side of the two RAM chips.
  7. Acer Travelmate 220 RAM Replacement: Schritt 7, Bild 1 von 3 Acer Travelmate 220 RAM Replacement: Schritt 7, Bild 2 von 3 Acer Travelmate 220 RAM Replacement: Schritt 7, Bild 3 von 3
    • Locate the first RAM chip.
    • Push the plastic levers away from the first RAM chip.
  8. Acer Travelmate 220 RAM Replacement: Schritt 8, Bild 1 von 3 Acer Travelmate 220 RAM Replacement: Schritt 8, Bild 2 von 3 Acer Travelmate 220 RAM Replacement: Schritt 8, Bild 3 von 3
    • Lift the RAM chip from the compartment.
    • Repeat steps 7 and 8 to replace the second RAM chip.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
Kevin A
55 Reputation
1 Anleitung geschrieben
UW Stout, Team 5-5, Zhou Fall 2011 Mitglied von UW Stout, Team 5-5, Zhou Fall 2011
UWSTOUT-ZHOU-F11S5G5
3 Mitglieder
2 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 4
Letzte 30 Tage: 27
Insgesamt: 3,646
