Einleitung
This guide will show you how to replace the stand on your Acer X191 monitor, if it is broken, or if you want to swap it out for another stand or maybe a wall mount
Was du brauchst
Lay the monitor on a flat surface, facedown.
Use a #1 Phillips screwdriver to remove the 4x 10.2mm screws securing the stand to the back panel.
Remove the stand from the back panel by pulling it up.
Fast fertig!
Abschluss
