Zum Hauptinhalt wechseln
Acoustic Guitar Bridge Replacement
Was du brauchst
  1. Acoustic Guitar Bridge Replacement, Bridge: Schritt 1, Bild 1 von 2 Acoustic Guitar Bridge Replacement, Bridge: Schritt 1, Bild 2 von 2
    • Remove the guitar strings.
    • Use a paper towel to remove any dust and debris from the neck of the guitar.
  2. Acoustic Guitar Bridge Replacement: Schritt 2, Bild 1 von 1
    • Apply a warm heating pad to the bridge to loosen the glue.
  3. Acoustic Guitar Bridge Replacement: Schritt 3, Bild 1 von 1
    • Carefully remove the bridge of the guitar with a putty knife or something with a thin dull blade.
    • Be careful to not scratch the finish of the guitar.
  4. Acoustic Guitar Bridge Replacement: Schritt 4, Bild 1 von 1
    • Carefully remove any excess glue or debris on the body of the guitar from the old bridge.
  5. Acoustic Guitar Bridge Replacement: Schritt 5, Bild 1 von 1
    • Apply wood glue to the new bridge and attach it to where the old one used to be.
  6. Acoustic Guitar Bridge Replacement: Schritt 6, Bild 1 von 1
    • Use a C-clamp to gently clamp the bridge to the body of the guitar.
  7. Acoustic Guitar Bridge Replacement: Schritt 7, Bild 1 von 1
    • Wait and let the glue dry.
    • Time will very based on what glue you use, but to be safe, let it sit for at least 12 hours.
  8. Acoustic Guitar Bridge Replacement: Schritt 8, Bild 1 von 1
    • Remove the clamp after glue has dried.
  9. Acoustic Guitar Bridge Replacement: Schritt 9, Bild 1 von 1
    • Restring the guitar.
  10. Acoustic Guitar Bridge Replacement: Schritt 10, Bild 1 von 1
    • Play!
Ziellinie
Eine weitere Person hat diese Anleitung absolviert.
Mitchell McCaskill
211 Reputation
1 Anleitung geschrieben
Ein Kommentar
This is a good guide Mitchell. I would encourage anyone attempting this type of a job to go watch some of the videos on YouTube by Mr. Ted Woodford. He goes into great detail about the various pitfalls of removing bridges, they aren't always as simple. Personally I don't think this repair is something to be classified as 'easy' as well. Different guitars can have very very tough adhesive bonds. I had to remove a Taylor bridge once that was a bear to get off and ensure that it went back on cleanly. The bridge can also warp and deform once it comes free of the top, so it's a good idea to clamp the bridge to a known flat surface. I appreciate the steps you outlined here though.
https://youtu.be/lsFBqPsB7VE
Ryan Field - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 30
Insgesamt: 3,123
