Zum Hauptinhalt wechseln
Acrylic Nail Tip Replacement
Was du brauchst
    1. Acrylic Nail Tip Replacement, Acrylic Nail Tip: Schritt 1, Bild 1 von 1
      • File the nail in a back-and-forth motion with the nail file on the accessible part of the natural nail until it is no longer smooth.
      • Try not to file the acrylic nail that is is still attached to your natural nail, as it will not fit the part that broke.
      Frag FixBot
      Kommentar hinzufügen
    2. Acrylic Nail Tip Replacement: Schritt 2, Bild 1 von 1
      • Carefully place a drop of nail glue on the natural nail and let the glue sit for about 5 seconds.
      • Do not use more than 1-2 drops of nail glue.
      Frag FixBot
    3. Acrylic Nail Tip Replacement: Schritt 3, Bild 1 von 2 Acrylic Nail Tip Replacement: Schritt 3, Bild 2 von 2
      • Place a nail tip in its original position and hold it in place for about 20 seconds, or until it is fully dry.
      Frag FixBot
    4. Acrylic Nail Tip Replacement: Schritt 4, Bild 1 von 2 Acrylic Nail Tip Replacement: Schritt 4, Bild 2 von 2
      • Pour 30 milliliters of monomer in a small glass bowl.
      • Liquid nail monomer has a strong odor and is highly flammable.
      • Do not reuse the glass bowl for any food products because of possible chemical residue.
      Frag FixBot
    5. Acrylic Nail Tip Replacement: Schritt 5, Bild 1 von 3 Acrylic Nail Tip Replacement: Schritt 5, Bild 2 von 3 Acrylic Nail Tip Replacement: Schritt 5, Bild 3 von 3
      • Dip the brush in the monomer and lightly tap it on the paper towel to remove the excess.
      Frag FixBot
    6. Acrylic Nail Tip Replacement: Schritt 6, Bild 1 von 2 Acrylic Nail Tip Replacement: Schritt 6, Bild 2 von 2
      • Place the tip of the brush in clear acrylic powder at about an 80-degree angle; collect it on one side of the brush.
      Frag FixBot
    7. Acrylic Nail Tip Replacement: Schritt 7, Bild 1 von 3 Acrylic Nail Tip Replacement: Schritt 7, Bild 2 von 3 Acrylic Nail Tip Replacement: Schritt 7, Bild 3 von 3
      • Apply the acrylic powder to the nail, and in a dabbing, downward motion, smooth the acrylic over the nail from top to bottom.
      Frag FixBot
    8. Acrylic Nail Tip Replacement: Schritt 8, Bild 1 von 1
      • Place the nail under the UV/LED lamp until hard and firm.
      Frag FixBot
    9. Acrylic Nail Tip Replacement: Schritt 9, Bild 1 von 3 Acrylic Nail Tip Replacement: Schritt 9, Bild 2 von 3 Acrylic Nail Tip Replacement: Schritt 9, Bild 3 von 3
      • Use a nail drill to file the nail to achieve an even acrylic coat by drilling in a side-to-side motion, working your way from top to bottom.
      • Use a speed of 7-9 on the nail drill.
      • If you do not have a nail drill, you can also use a nail file.
      Frag FixBot
    10. Acrylic Nail Tip Replacement: Schritt 10, Bild 1 von 3 Acrylic Nail Tip Replacement: Schritt 10, Bild 2 von 3 Acrylic Nail Tip Replacement: Schritt 10, Bild 3 von 3
      • Buff the nail until it is smooth, and use a paper towel to wipe off excess powder.
      Frag FixBot
    11. Acrylic Nail Tip Replacement: Schritt 11, Bild 1 von 3 Acrylic Nail Tip Replacement: Schritt 11, Bild 2 von 3 Acrylic Nail Tip Replacement: Schritt 11, Bild 3 von 3
      • Optional: coat the nail with clear polish.
      Frag FixBot
Ziellinie
Eine weitere Person hat diese Anleitung absolviert.
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 20
Letzte 30 Tage: 43
Insgesamt: 872
