Zum Hauptinhalt wechseln
Adjust Goose-neck (adjustable quill stem) on Specialized Expedition
Was du brauchst
  1. Adjust Goose-neck (adjustable quill stem) on Specialized Expedition, Adjust Goose-neck (adjustable quill stem) on Specialized Expedition: Schritt 1, Bild 1 von 2 Adjust Goose-neck (adjustable quill stem) on Specialized Expedition, Adjust Goose-neck (adjustable quill stem) on Specialized Expedition: Schritt 1, Bild 2 von 2
    • Remove the bolt cover with a flathead screwdriver.
  2. Adjust Goose-neck (adjustable quill stem) on Specialized Expedition: Schritt 2, Bild 1 von 3 Adjust Goose-neck (adjustable quill stem) on Specialized Expedition: Schritt 2, Bild 2 von 3 Adjust Goose-neck (adjustable quill stem) on Specialized Expedition: Schritt 2, Bild 3 von 3
    • Loosen the goose-neck (adjustable quill stem) with a 6 mm Allen wrench.
    • After loosening the goose-neck (adjustable quill stem), it still may be stiff. Hold the wheel from turning and twist the handlebars from side to side.
    • If quill stem is still stuck then place 6 mm Allen wrench firmly into bolt and tap with a mallet.
    • Position the handlebars to your preferred height. Make sure not to pull cable and housing to tight. I could adversely effect shifting and braking performance.
    • Make sure you don't raise quill stem above minimum insert line.
  3. Adjust Goose-neck (adjustable quill stem) on Specialized Expedition: Schritt 3, Bild 1 von 3 Adjust Goose-neck (adjustable quill stem) on Specialized Expedition: Schritt 3, Bild 2 von 3 Adjust Goose-neck (adjustable quill stem) on Specialized Expedition: Schritt 3, Bild 3 von 3
    • Align the direction of the goose-neck (adjustable quill stem) with the front tire.
    • Firmly tighten the goose-neck (adjustable quill stem) bolt using a 6 mm Allen wrench.
    • Pop the bolt cover back on.
    • If calling a bicycle repair shop, refer to it as a adjustable quill stem (technical term) instead of goose-neck as mechanic may not know what you are talking about.
Ziellinie
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
aaron thielk
1.882 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 5-13, Maness Fall 2010 Mitglied von Cal Poly, Team 5-13, Maness Fall 2010
CPSU-MANESS-F10S5G13
4 Mitglieder
17 Anleitungen geschrieben
Ein Kommentar
Anyone know where/how to buy a replacement bolt cover?
Bennett Hart - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 9
Insgesamt: 9,220
