Einleitung
This guide will show you how to adjust the height of the handle bars and align the stem with the front wheel.
Ersatzteile
Kein Ersatzteil erforderlich.
  1. Remove the bolt cover with a flathead screwdriver. Remove the bolt cover with a flathead screwdriver.
    • Remove the bolt cover with a flathead screwdriver.
  2. Kostenloser Versand für alle Bestellungen über 100,00 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
    Erfolgreich repariert? Genial!
    Teile ein Foto deiner Reparatur mit dem Hashtag #ImAGenius
    Wir sind alle Genies
  3. Loosen the goose-neck (adjustable quill stem) with a 6 mm Allen wrench. After loosening the goose-neck (adjustable quill stem), it still may be stiff. Hold the wheel from turning and twist the handlebars from side to side. If quill stem is still stuck then place 6 mm Allen wrench firmly into bolt and tap with a mallet.
    • Loosen the goose-neck (adjustable quill stem) with a 6 mm Allen wrench.
    • After loosening the goose-neck (adjustable quill stem), it still may be stiff. Hold the wheel from turning and twist the handlebars from side to side.
    • If quill stem is still stuck then place 6 mm Allen wrench firmly into bolt and tap with a mallet.
    • Position the handlebars to your preferred height. Make sure not to pull cable and housing to tight. I could adversely effect shifting and braking performance.
    • Make sure you don't raise quill stem above minimum insert line.
  4. Align the direction of the goose-neck (adjustable quill stem) with the front tire. Firmly tighten the goose-neck (adjustable quill stem) bolt using a 6 mm Allen wrench. Pop the bolt cover back on.
    • Align the direction of the goose-neck (adjustable quill stem) with the front tire.
    • Firmly tighten the goose-neck (adjustable quill stem) bolt using a 6 mm Allen wrench.
    • Pop the bolt cover back on.
    • If calling a bicycle repair shop, refer to it as a adjustable quill stem (technical term) instead of goose-neck as mechanic may not know what you are talking about.
Ziellinie
Ein weiterer Nutzer hat diese Anleitung absolviert.
aaron thielk
1.726 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 5-13, Maness Fall 2010 Mitglied von Cal Poly, Team 5-13, Maness Fall 2010
CPSU-MANESS-F10S5G13
4 Mitglieder
11 Anleitungen geschrieben
Anyone know where/how to buy a replacement bolt cover?
Bennett Hart - Antwort
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 13
Insgesamt: 7,874
