Zum Hauptinhalt wechseln
Adjust the Action (String Height) on Ibanez SR405QM
Was du brauchst
  1. Adjust the Action (String Height) on Ibanez SR405QM, Adjust the Action (String Height) on Ibanez SR405QM: Schritt 1, Bild 1 von 2 Adjust the Action (String Height) on Ibanez SR405QM, Adjust the Action (String Height) on Ibanez SR405QM: Schritt 1, Bild 2 von 2
    • Pay attention to the distance between both the fretboard and pickups.
    • Test the strings by plucking and take note of which ones are difficult to play or are producing an unpleasant metallic sound.
  2. Adjust the Action (String Height) on Ibanez SR405QM: Schritt 2, Bild 1 von 2 Adjust the Action (String Height) on Ibanez SR405QM: Schritt 2, Bild 2 von 2
    • Using a 2 mm Allen Key turn the corresponding string's screw clockwise to raise the string and counterclockwise to lower the string.
    • The screw is located on the bridge of the guitar next to its corresponding string.
    • While modifying a strings height try plucking the string and listening to the sound produced until at desired sound.
Ziellinie
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Chris Pittner
220 Reputation
7 Anleitungen geschrieben
Cal Poly, Team 5-18, Forte Winter 2013 Mitglied von Cal Poly, Team 5-18, Forte Winter 2013
CPSU-FORTE-W13S5G18
4 Mitglieder
9 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 30
Letzte 30 Tage: 117
Insgesamt: 6,231
