Zum Hauptinhalt wechseln
Adjusting Nishiki Aero II Seat
Was du brauchst
  1. Adjusting Nishiki Aero II Seat, Adjusting Nishiki Aero II Seat: Schritt 1, Bild 1 von 3 Adjusting Nishiki Aero II Seat, Adjusting Nishiki Aero II Seat: Schritt 1, Bild 2 von 3 Adjusting Nishiki Aero II Seat, Adjusting Nishiki Aero II Seat: Schritt 1, Bild 3 von 3
    • Loosen the bolt that secures your seat.
    • To do so, use one wrench to hold the larger nut on the left side of the bike still while you loosen the nut on the right.
  2. Adjusting Nishiki Aero II Seat: Schritt 2, Bild 1 von 2 Adjusting Nishiki Aero II Seat: Schritt 2, Bild 2 von 2
    • Now that it can move, move the seat by wiggling it and pulling it in the direction you want to adjust it.
    • You want to the adjust the seat so that, when a pedal is at the far end of its rotation, your leg is fully extended.
    • Don't worry about getting it perfect on the first try. Instead, guess your adjustment, tighten the bolt a little bit, try it out, and adjust again until you get it right.
  3. Adjusting Nishiki Aero II Seat: Schritt 3, Bild 1 von 1
    • Once your seat is at the desired height, you just tighten the bolt the same way you loosened it.
    • Use two wrenches, one to hold it still and the other to tighten the nut.
    • Make sure it's very tight, or else the seat might twist or lower over time.
Abschluss
Tobias Elder
113 Reputation
7 Anleitungen geschrieben
Cal Poly, Team 21-53, Johann Spring 2013 Mitglied von Cal Poly, Team 21-53, Johann Spring 2013
CPSU-JOHANN-S13S21G53
4 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 29
Insgesamt: 2,778
