Zum Hauptinhalt wechseln
Adjusting Right/Left Speaker Balance
  1. Adjusting Right/Left Speaker Balance, Adjusting Right/Left Speaker Balance: Schritt 1, Bild 1 von 1
    • The balance knob is the rightmost knob on the front panel.
  2. Adjusting Right/Left Speaker Balance: Schritt 2, Bild 1 von 2 Adjusting Right/Left Speaker Balance: Schritt 2, Bild 2 von 2
    • Turning the balance knob to the right increases the sound played by the right speaker.
    • Turning the knob left will increase the sound played by the left speaker.
  3. Adjusting Right/Left Speaker Balance: Schritt 3, Bild 1 von 2 Adjusting Right/Left Speaker Balance: Schritt 3, Bild 2 von 2
    • Turning the knob all the way to the right will make the right speaker play all the sound.
    • Turning the knob all the way to the left will make the left speaker play all the sound.
  4. Adjusting Right/Left Speaker Balance: Schritt 4, Bild 1 von 1
    • The default position is center, which should play the sound equally by both speakers.
    • If this position does not play the sound equally by both speakers, experiment with different knob positions until the speakers play the sound equally.
Ziellinie
Jan Vazquez
239 Reputation
1 Anleitung geschrieben
Cal Poly, Team 27-92, Amido Spring 2010 Mitglied von Cal Poly, Team 27-92, Amido Spring 2010
CPSU-AMIDO-S10S27G92
4 Mitglieder
7 Anleitungen geschrieben
Ein Kommentar
Finally, I can die in peace
john goor - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 16
Insgesamt: 5,701
