Zum Hauptinhalt wechseln
Adjusting the alarm glass breakage microphone sensitivity
Was du brauchst
  1. Adjusting the alarm glass breakage microphone sensitivity: Schritt 2, Bild 1 von 1
    • Once the glove box is out of the way, it's easy to spot the alarm unit. The green connector will be plugged into it. I had already unplugged it when I took this picture.
  2. Adjusting the alarm glass breakage microphone sensitivity: Schritt 3, Bild 1 von 1
    • It may be stubborn to get out because it is stuck down with double stick foam pads.
  3. Adjusting the alarm glass breakage microphone sensitivity: Schritt 4, Bild 1 von 1
    • Remove the 4 screws (may be under the foam strips). This is the bottom of the circuit board.
  4. Adjusting the alarm glass breakage microphone sensitivity: Schritt 5, Bild 1 von 1
    • Turn the board over and locate the 2 position dip switch.
    • This dip switch adjusts the glass breakage microphone sensitivity
    • Sensitivity settings:
    • 1 off & 2 off = high
    • 1 on & 2 off = mid (factory setting)
    • 1 off & 2 on = low
    • 1 on & 2 on = super low
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
mpeeples
184 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 22
Insgesamt: 2,566
